what next?
i know a couple ppl that drive mach 1's
is he in that mustang club that always rides around?
i've been looking into lightweight pulleys, but am kinda skeptical so far...
i think i'm gonna do some suspension mods, then work on the appearance, starting w/ some headlights
5K miles is not much. If you drive hard all the time be prepared to replace your cluch after a few years. You will get good mileage and wear if you are nice to it most of the time.
i have 8k in my stockers and they are fine i can see alot more than the stock bulb...people say they blind you and this and that, but ive had no probs with mine...ive had bad experiences with aftermarket headlights so im not going to buy those or pay 600+ for retro's...ide say go wit some springs mabe sway bars or something....or the K04+ upgrade
Your right, 10000k is blue. Maybe if you add a red light somewhere and a siren to your car you can run through red lights on the intersection.
Retrofits use oem projectors/ballasts/bulbs from acura's/infiniti's/audi's, your cheap hid kit will die quicker than any retrofit out there.
Well, you want more perfprmance..... Here are some other things to look into..... Fuel pump/high flow filter, Coil pack springs, and re-tune....... You can always squeez more out of it.
Stock appearing, but flows 25% better (32lbs/min vs. 40lbs/min). On the cobalt ss, there are four bolts that connect the turbo outlet to a cast iron elbow that than connects to the downpipe, of the 4, 3 are hard to get at. I could not get them laying down on my back with just jacks. But when i had it professionally installed they used a lift and got the bolts off without any extensions. Ive had mined tuned and am making 301HP and 310TQ. Low considering some people with only a tune make more than this, but i have a HP Tuners module in the mail from Dejon and am going to work with Bald Turbo Freak to get a lot better numbers, hopefully. In an ideal situation and dyno, numbers should read 320-330HP and 350-360TQ
Its not **** talk, why do you want blue lights on your car? Isn't the point of hid's to have more light? Those high K lights will give you less output than 4300k ones and will make you an easy target for cops to pick on, they hate people who have these blinding hid kits on their cars.
