what should the peak bost be
Old Mar 21, 2011 | 10:49 AM
BIG SS TC's Avatar
Well lately I've been getting 17 psi peak boost and its staying their till I let off or shift then it goes to 15 then goes back up. I thought its supposed to be between 13-15psi and I'm stock
Old Mar 21, 2011 | 10:50 AM
northvibe's Avatar
are you still stock? It also depends on your altitude. But stock boost is around 15lbs and may spike a little.
Old Mar 21, 2011 | 11:02 AM
BIG SS TC's Avatar
Yeah still stock till April also I did just by the car about a month ago and ill check the gps to see my altitude but I'm pritty darn sure I'm at like 800 above
Old Mar 21, 2011 | 11:14 AM
BIG SS TC's Avatar
924 feet
Old Mar 21, 2011 | 11:18 AM
umrdyldo's Avatar
17 is common when it's warm outside. It will spike to 17 and settle down to 15
Old Mar 21, 2011 | 11:22 AM
TommyP's Avatar
AWD > FWD
There are a lot of things that affect how much you boost. Altitude, air temp, humidity. Stock, the car will change boost however it needs to in order to achieve 260hp. When it's colder, the air is more dense, and you'll boost less but make the same amount of power.
Old Mar 21, 2011 | 11:25 AM
BIG SS TC's Avatar
I live in upstate ny and it was 30 out ay night
OPCrer
Sep 27, 2015 08:11 PM
Twincharged
May 1, 2012 12:46 AM
NightriderCobaltSS
Feb 7, 2007 12:22 PM
leviticus88
Feb 3, 2007 08:44 AM
memphisr24
Dec 22, 2006 01:54 AM
