What wire do u use on maf for meth kit???
Old Apr 9, 2011 | 12:40 PM
tomj77's Avatar
really need to know today since im gonna be wireing it up today. please and thank you.
Old Apr 9, 2011 | 12:42 PM
Gunney_07's Avatar
do have stock or stage kit sensors?
Old Apr 9, 2011 | 12:50 PM
tomj77's Avatar
stock
Old Apr 9, 2011 | 12:55 PM
Gunney_07's Avatar
(pin c) is your 5v ref wire you need to tap
Old Apr 9, 2011 | 04:22 PM
09CobaltSS1's Avatar
I hope you just made a typo and won't be wiring off of your maf.. You'll need to tap off of the manifold map sensor for boost reference
Old Apr 9, 2011 | 04:58 PM
FF_ace's Avatar
Not the maf but the wire you need to tap into is the manifold map sensor and the write is lime green iirc when I did my meth kit
Old Apr 9, 2011 | 06:50 PM
tomj77's Avatar
idk, instructions say wire goes to maf sensor singal. this runs on maf not boost. its a snow kit. so if it says get ur signal from maf why would i tap into map sensor?
Old Apr 9, 2011 | 06:59 PM
tomj77's Avatar
what color is it?
Old Apr 9, 2011 | 09:55 PM
Gunney_07's Avatar
your tapping the lower one on the charge pipe right? im not sure on the color, but it should be second one in from the left......
if you tap the wrong one, as soon as you turn the key on it will spray, so you'll know if it's wrong!
Old Apr 9, 2011 | 10:35 PM
tomj77's Avatar
no im not the wire goes on the maf not the map, this is a maf controlled kit not a boost controlled kit
Old Apr 9, 2011 | 10:38 PM
tomj77's Avatar
ok only people with maf controlled kits please, i dont wanna know where the wire goes on boost controlled kits. this is maf controlled only.
Old Apr 9, 2011 | 10:39 PM
tomj77's Avatar
unless im totally wrong id assume a maf controlled kit hooks up to the maf sensor. am i wrong here?
Old Apr 9, 2011 | 10:58 PM
Gunney_07's Avatar
what kit do you have? and what controller?
Old Apr 10, 2011 | 01:24 AM
tomj77's Avatar
snow stage 2 maf controlled. and i got the diagram for the maf, so i think i can figure it out. have non of u heard of maf controlled kits or what?
Old Apr 10, 2011 | 06:47 PM
tomj77's Avatar
well since no one could give me a straight answer i got the maf wireing diagram and hooked into the yellow mass air flow signal wire. snipped it, and soldered in the wire to the controller. system is all up and running and works great. sprays depending on airload going into the motor not air pressure in manifold. no to get the bung installed so i can actually finish hooking it up.
Old Apr 10, 2011 | 06:59 PM
Gunney_07's Avatar
cool, glad every thing worked out, sorry i could assist you any further than i did.
Old Apr 10, 2011 | 08:02 PM
tomj77's Avatar
well if anyone installs a maf controlled kit i guess i can help them lol
Old Apr 11, 2011 | 11:58 AM
hmm.. I honestly had no idea the snow performance kit referenced air load %'s instead of boost signal. ya learn something new everyday. Good info to know..
Old Apr 11, 2011 | 12:27 PM
06arrivalSC's Avatar
Yea I didn't know there was a kit that was MAF based vs boost activation, it actually seems like it would be a better method since it's related to air coming in so it's spraying accordingly vs just a constant spray after a certain manifold pressure is reached, or on a progressive style kit, just guessing which boost level you think it should start spraying at and when it should be at full spray...question is, when does the meth start spraying on the MAF style kit? I assume it would be when the incoming airload exceeded a certain amount (MAF frequency) but the nice thing about boost activation is you can physically see/know when it's going to start spraying...curious to learn more about how the MAF based kit works
Also curious as to if it's more of a pain in the ass to tune for vs a boost activation style kit
Old Apr 11, 2011 | 07:04 PM
tomj77's Avatar
they actually have both, u can get either boost controlled or maf controlled.
Old Apr 11, 2011 | 07:13 PM
tomj77's Avatar
what u figured is exactly right. it actually pretty easy to to dial in, just turn the dial and give it a test, probably a little more of a pain than boost controlled system. the recommended start time i cant use cause of cat warm up mode, it starts to spray. lol but ya, i guess ill have to do some reading on whats the best to set it at. as for tuneing for it, dont know. im not gonna tune for it, i just want it for cooling and better gas, i am hoping vince will lean my tune out a bit for it though. its my excuse to get him to do it, cause he wont otherwise . lol
Old Apr 14, 2011 | 11:40 PM
tomj77's Avatar
kit install almost done. just got to drill the charge pipe and install the nossel. i did put a toggle switch with an led in my car to tune system on or off depending if im using it or not. dont really want it on when driving on stock tune, plus it lets me know if the system is energized and no fuse is blown or any other electrical issues that could arise. i thought it was a good idea anyway
Old Apr 14, 2011 | 11:46 PM
sheldon729's Avatar
it goes to the yellow wire of the maf harness lol i got the same kit as you, it is not the boost controlled kit it is a maf controlled kit. Snow also make the boost controlled kit as well as the maf controlled.
It is PIN A yellow wire is maf sensor signal. you tap that one.
Old Apr 14, 2011 | 11:54 PM
tomj77's Avatar
ya i already know, and did it. would have been nice if u were a little earlier on this. lol i ended up going on my alldata and getting the diagram for the maf harness.
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
