where to…. meth injection
Drill a hole in your washer tank near the top of the neck and run the line through it and down to the bottom
Mount the pump somewhere near the passenger side strut tower
Run the line to a throttle body spacer (i have one for sale btw)between the throttle body and supercharger
I made my own tank out of 4" pvc tubing and caps and put it between the bumper support and radiator,clamped to the bumper support. Made a thread on it if you feel like digging for it
Nm found it
https://www.cobaltss.net/forums/show...972&styleid=10
Nm found it
Last edited by riceburner; Apr 17, 2014 at 07:13 PM. Reason: Automerged Doublepost
I just ordered a Devil's Own kit. I was looking to run a 2 quart tank and mount it similar to an option B overflow tank. The other option is to drill into the washer fluid container which requires us to remove the bumper cover. Still on the fence on which to go with.
Like i said no need to remove bumper to use windshield fluid resiovior, drill a small hole near the top of the filler neck and shove the meth line all the way down to the bottom, secure a filter over the end of the line to be safe
