Whp and wtq gusses anyone???
Old May 11, 2011 | 12:52 PM
ssblackstealth's Avatar
corn gas ftw....
08 lnf
lsd
trifecta E85 24psi
stock down pipe gutted
muffler delete
hahn intake
dejon hot pipe
zzp lower pipe
mpx fmic
forge bypass valve
ngk plugs
stage 1 sensors
my old set-up made 311whp
with no e85, 23psi, hks bov, and crazy steve fmic..
let the guessing begin!! i dyno friday and will update then
Old May 11, 2011 | 12:55 PM
RyRidesMotox's Avatar
Originally Posted by ssblackstealth
08 lnf
lsd
trifecta E85 24psi
muffler delete
hahn intake
dejon hot pipe
zzp lower pipe
mpx fmic
forge bypass valve
ngk plugs
stage 1 sensors
Are your NGKs a step colder?
JustACobalt's Avatar
359.2 whp 385.6 wtq
Old May 11, 2011 | 12:57 PM
corn gas ftw....
no sir just iridiums..cause the step colder plugs always messed my car up for some reason.....
Originally Posted by JustACobalt
359.2 whp 385.6 wtq
that is really close to my guess !!
Last edited by ssblackstealth; May 11, 2011 at 12:57 PM. Reason: Automerged Doublepost
Old May 11, 2011 | 12:59 PM
Grishbok's Avatar
are you talking average of 3 pulls?
id say 5 and 12...
Old May 11, 2011 | 01:01 PM
nizzle's Avatar
330 - 340 whp & tq
corn gas ftw....
id say 5 and 12...
yea im doing three pulls and taking the highest pull....
5 and 12? more?
Old May 11, 2011 | 01:02 PM
corn gas ftw....
Originally Posted by nizzle
330 - 340 whp & tq
i wanna hit 350whp even soooooo bad!
Old May 11, 2011 | 01:03 PM
nizzle's Avatar
it's possible
Old May 11, 2011 | 01:05 PM
corn gas ftw....
it's possible
if im close im gunna stay on that dyno till i hit it hahaha grab a couple bags of ice to throw on her or somethin lol
Old May 11, 2011 | 01:08 PM
nizzle's Avatar
make it happen, I'll be waiting for the numbers. good luck
Old May 11, 2011 | 01:09 PM
Dude on my car I am MAXING out the fuel on E85/91 50/50 blend. If you are on a dynojet I am guessing 400lb/ft and 360hp at the wheels, mustang dyno will be less.
41.x lbs/min on a stock turbo with full bolt ons.
Low rail pressure... I hope you have access to HP tunes. The orange 983 is actual pressure the blue 2076 right below it is demanded... can't get enough E into the cylinders. I just got an update from terminator that I haven't logged it yet. Your mods list is similar to mine.
Old May 11, 2011 | 01:30 PM
Gremlin85's Avatar
350/390
Old May 11, 2011 | 01:34 PM
N1ckateen's Avatar
enough to smoke me! lol
Old May 11, 2011 | 01:37 PM
nizzle's Avatar
Old May 11, 2011 | 01:40 PM
BYT*SS*TURBO's Avatar
The problem is like on Drew's car, I think David used my advice and got it working. There just isnt enough fuel there to run steady fuel pressure, it needs to ramp up. Which has no bearing on power/tq Ive found either, so ramp it up and keep it safe!
You won't max the fueling on stock turbo and a Blend, we recently made 368whp on the stock turbo with a 1:1 blend and showed no signs of running out of fuel. The only issues I still have is with a aggressive Full E85 tune on a bolted car.
But for the OP: 350/400
Old May 11, 2011 | 01:42 PM
Rissa's Avatar
Get rid of the stock downpipe.
Old May 11, 2011 | 01:46 PM
RoadconeTuning's Avatar
342/406
Old May 11, 2011 | 01:48 PM
nizzle's Avatar
i wish there were more E pumps in my area. nearest E85 station is about 20 miles away
Old May 11, 2011 | 01:49 PM
CobaltVenomSS's Avatar
360/405
Old May 11, 2011 | 01:56 PM
idunn's Avatar
you could do what these guys did...
YouTube - leafblower turbo
Old May 11, 2011 | 02:01 PM
nizzle's Avatar
never taking my car to that shop. what a bunch of re-re's
Old May 11, 2011 | 02:06 PM
Its just when the midrange torque hits that I run into the problem. After that is when the airflow is the highest and it sustains the demanded pressure. I dunno though cuz me and computer tuning do not mix, my last car had a holley 650 so jets are alot different... I'm gonna log my new tune file today and see what it looks like.
Old May 11, 2011 | 02:15 PM
Above 4500 you won't have the issue since the HPFP is fully up to speed at that point. Its below where you need to make the proper adjustments to get enough fuel in there
Old May 11, 2011 | 02:26 PM
raver0789's Avatar
If you can't get fuel in, cut it to 23psi and a 50/50 mix.
You're going to be happy!
350/400 is the guess.
