will a manual boost controller work?
Old Feb 27, 2009 | 05:31 PM
cardelino18's Avatar
Exclamation will a manual boost controller work?
will a manual boost controller work if i have my clear image tune and want to push about 22-23psi? im pushing 21 now... i want to push 23
Old Feb 27, 2009 | 05:46 PM
red2001ss's Avatar
You can try.
Old Feb 27, 2009 | 08:37 PM
turbobalt's Avatar
Well that's how I have mine.I'm pshing 23psi
Old Feb 27, 2009 | 08:57 PM
peachpuff's Avatar
Boost doesn't dictate how much power you're making... airflow does. If you have stock intake/exhaust/cat you'll need to push more psi to make the same power as someone running lower boost with a hiflow cat/intake/catback.
Also i wouldn't bother with an mbc on an lnf, the ecm controls how much boost you'll be running anyway.
Old Feb 27, 2009 | 09:27 PM
orbalt08's Avatar
^^Not if you are running an aftermarket tune as he stated in his first post
Old Feb 27, 2009 | 10:29 PM
peachpuff's Avatar
What does that have to do with anything? Boost is simply the amount of pressure in the intake manifold and nothing more. I've seen plenty of hptuner logs where people are running 21-22 psi yet only pushing 30lbs/min of airflow, im running less psi yet flowing more air due to a less restrictive setup.
May i suggest some reading material on how turbo's work from Corky Bell.
Old Feb 28, 2009 | 10:15 AM
orbalt08's Avatar
I was simply stating that with an aftermarket tune, the ecm no longer restricts the boost to keep the power at 260/260.
Old Feb 28, 2009 | 10:18 AM
Terminator2's Avatar
The tune you have is set for 21.98 lbs exactly as the test car was. If you have the same mods you will see 21.98 lbs. The most boost you can run is 22.5 lbs. Any more and the ECM will slam the throttle shut to bring it back down.
Old Feb 28, 2009 | 10:22 AM
peachpuff's Avatar
We were both talking about different things i guess.
Old Feb 28, 2009 | 10:31 AM
orbalt08's Avatar
Good book btw
Old Mar 2, 2009 | 11:39 PM
idk i order it... lets see when i put it on... ill tell you guys how it went when i put it on and try to push as much as i can... ill let you know....
Old Mar 5, 2009 | 12:49 PM
widowedeight's Avatar
info?
Old Sep 3, 2009 | 03:33 AM
mkriebs's Avatar
Card... got any more info on this? I am going to install my hombrew boost controller as soon as I get the car back.
Old Sep 4, 2009 | 09:46 AM
oldskool's Avatar
Some ppl are finding that an MBC is necessary when running high boost pressure. apparently our wastegate is pushed open from excessive backpressure and we are out of boost control PW at high boost, so increasing spring preload and an MBC solve these problems. I wonder if 22-23psi is the limit on a full bolton system with the stock turbo/wastegate actuator. But then there's "infiniboost" that seems to have no problems wit the stock hardware.
I wish we knew exactly the duty cycle of our stock boost control solenoid, and how much wastegate preload we can add before creeping to dangerous levels...
This of course assumes your tune will allow the extra airflow or "load"
Old Sep 4, 2009 | 10:50 AM
Gimpster's Avatar
I'd guess that Vince/Trifecta basically unlocked more code surrounding the duty cycle of the boost control solenoid. Its pretty obvious from his and other posts/logs the car can hold boost to redline reasonably well when in the right hands.
I think even some of the HPT guys have been able to get it up pretty high lately? Although the boost control on HPT seems pretty ambigious from what I've seen in person on the SS/TC.
Maybe infiniboost means exactly what the name implies, the BCS is at 100% (or damn near) and the turbo is basically building as much boost as possible. We'd wire WG shut on DSM's all the time on 16g's and get 32-36psi (on race gas!) usually on a good 3" exhaust. At that point its just a matter of how much air you can move
Old Sep 4, 2009 | 10:52 AM
mkriebs's Avatar
Yeah, I maintain 21 psi all the way to redline. I just want the opportunity to push a bit more boost.
Old Sep 4, 2009 | 11:17 AM
pt5457balt's Avatar
Isn't that a feature of the overboost protection?
Does HPtunersBETA allow for that to be disabled?
Old Sep 4, 2009 | 11:31 AM
Yes and yes no over or underboost on my car.
Old Sep 4, 2009 | 02:13 PM
mkriebs's Avatar
Term, are you running a MBC?
Old Sep 4, 2009 | 02:57 PM
Not yet. Soon.
Old Sep 4, 2009 | 04:54 PM
mkriebs's Avatar
What you waiting for?
Old Sep 4, 2009 | 05:03 PM
Money LOL. It is only $100 but I am kinda poor right now.
Old Sep 4, 2009 | 05:20 PM
mkriebs's Avatar
You have PM. I just made one for $26. And I could have made it MUCH cheaper if I had shopped around.
Old Sep 4, 2009 | 05:26 PM
Thanks.
Old Sep 4, 2009 | 08:00 PM
Gimpster's Avatar
I've made quite a few being broke too, no biggie.
Have always made mine using these instructions: http://www.geocities.com/chmwatson/FAQs/mbc.html
$10-15 bucks will do ya! The only thing I change is a bolt with a wingnut for the locknut.
