Winter
Old Nov 23, 2009 | 04:35 PM
Baron7700's Avatar
Originally Posted by Shez
Looks like I'm in the market for some snow tires then. Any recommendations for some decent tires that fit the stock 18s? I'll just use these as winter wheels and buy a set of Ultraleggeras for the summer.
blizzaks, about 600 for the tires on tirerack for the stockers.
Old Nov 23, 2009 | 04:58 PM
kidcrash603's Avatar
I drove my car all winter up here in New Hampshire on the stock tires.... And now with 19500 miles on the same stockers, I'm going to do it again this winter....
Old Nov 23, 2009 | 08:09 PM
tomj77's Avatar
drive mine last winter, on stock tires, cause i had to, never found any winter rims. Never gonna do that again. I used an oil pan heat pad. works great. And this winter i got winter rims and tires, and i already tried em out in the snow, they work great as well.
Originally Posted by Permafried-
Yep, I paid $325 Canadian / tire for the 18" Alpin PA3...mind you the tread pattern and compound is pretty ridiculous. The ad for the tire should say "for the rally racing enthusiast in all of us". For the person questioning 18s availability let me know if you want a pic I'll pull my wheels/tires off the rack (still not on) and snap one for you to give you an idea .
As for the OP's question, you should be fine but as far as I know you can buy the block heater from GM and install it on the TC same as the SC.
i paid less than that for a new set of rims and winter tires.
Old Nov 23, 2009 | 08:21 PM
RevRud's Avatar
i just put winter wheels and tires on and the guy at discount tire said they dont put tire pressure moniters in winter tires because they get damaged easy from the salt. sounds like bs to me. and now i have to deal with "svc tpms" all winter.
Old Nov 23, 2009 | 08:36 PM
tomj77's Avatar
no one told me that. pfft, i got me some tpms off ebay, new, all 4 for $60. lol gotta love ebay.
Old Nov 23, 2009 | 09:01 PM
Rebel's Avatar
I had Yokohama W Drive Tires 215/45R18. They worked amazing in all of our major snow falls. And since they were on the stock rims I had the tpms on there. They worked fine all winter. The guy at discount tire told me to change the metal caps to plastic ones though, since the salt rusts the caps to the tpms monitor and ruins them. Even gave me the plastic caps.
Old Nov 23, 2009 | 09:09 PM
MaxVQ35DE's Avatar
youll die.... get winter tires
Old Nov 24, 2009 | 09:38 AM
Permafried-'s Avatar
I think it depends on conditions, but someone at our meets went through two pairs of them in the winter before saying "**** on this no more". The stems kept snapping off which in one case resulted in the tire going flat, in the second case it almost took his eye out 'cause he was adding air to the tires .
Old Nov 24, 2009 | 04:45 PM
Highbeamz's Avatar
I'm running Barum Polaris 2 for winters. I haven't gotten to try them on snow, but they're doing pretty good on ice. When it was really cold I just set my remote starter to start the car every 3-4 hours to keep the engine somewhat warm all the time.
Old Nov 24, 2009 | 10:56 PM
liu's Avatar
liu
Originally Posted by Force
It's not about not knowing how to drive. For you, slowbalt84, maybe it's not worth it for 2 annual snow falls. But for Shez, in NJ, GET SNOW TIRES. The SS/TC's stock Continentals are summer-only. The traction these tires get on cold tarmac or in snow is theoretical at best.
If people want to endanger themselves, cool... But don't endanger other road users by skidding around on tires designed for summer heat.
Agreed 100% towards this time of year I start slipping the tires in 2nd without any effort on my part.
Old Nov 24, 2009 | 11:55 PM
  #36
tom.g's Avatar
Seems a little bit over the top don't you think
Obviously when GM designed the engine and sold it without a block heater as an option knowing all well what sort of climates these cars would be driven in they gave this some thought. Never used a block heater in any of my cars neither does anyone I know, I think the synthetic oil helps with these cold starts.
Just my 2 cents.
Old Nov 25, 2009 | 02:02 PM
  #37
trey ss's Avatar
i nervous 2 drive mine at all this winter... it will b my 1st year driving in snow + first year driving in snow with a standard.. any pointers?
Old Nov 25, 2009 | 02:10 PM
  #38
Force's Avatar
The main tip for driving in snow is speed appropriate for conditions. Just take it easy and you'll be fine. Also, get snow tires. All-season tires are a joke and anyone who tells you otherwise either a) doesn't get any kind of real snowfall or b) doesn't know what they're talking about. Winter tires are worth every penny.
That being said, you'll find it easier driving a standard in snow than an automatic... A manual gives you much better control over the car's power delivery which translates into much better control in snow overall.
Old Nov 25, 2009 | 02:16 PM
  #39
slapbetcommissioner's Avatar
In around town driving its a good idea to keep your rpms low by upshifting a little sooner than normal. this keeps the torque low and keeps your tires firmly planted. Winter tires are a must.
Old Nov 25, 2009 | 02:17 PM
  #40
trey ss's Avatar
cool thanks... doubt my dad will go 4 snow tires hope he lets me drive the 4x4 jeep we r rebuilding..
Old Nov 25, 2009 | 02:24 PM
  #41
importkiller's Avatar
I have never owned snow tires, I had a 1997 escort, then a 2005 base cobalt and neither of them had traction control or ABS, never got in an accident or stuck, or anything, I took both cars up to the mountians skiing all the time, Just drive carefully if you get all seasons, now the summer tires on the SS/TC are not ment for snow so I will not drive the SS if it snows.
Old Nov 25, 2009 | 02:49 PM
  #42
Force's Avatar
Just because you haven't owned snow tires doesn't mean someone doesn't need them. You might be a simply amazing driver in the snow on all-seasons, but that's like saying you're an amazing Olympian with one leg... Sure, you do what you need to do, but people with the proper equipment will still kick your ass when it comes time to perform.
...Wow, that analogy was horrible.
Old Nov 25, 2009 | 02:57 PM
  #43
Basically if your going to drive it In the winter you shouldn't use the summer tires. And if your gonna waist your money on all seasons when you have summer tires already. buy snow tires for the winter. If not best of luck to you with those sport tires.
Old Nov 25, 2009 | 04:01 PM
  #44
trey ss's Avatar
i just have like two different kindas of tires.. on the front perelli rozzos and the back and one older looking perelli pzero and a brand new one.. lol..
Old Nov 25, 2009 | 05:54 PM
  #45
those will be like skating in bowling shoes. lol
Old Nov 27, 2009 | 11:19 AM
  #46
ßlĺçk§mókč's Avatar
my redline has a blockheater.. even checked to make sure it worked
Old Dec 10, 2009 | 07:19 PM
  #47
gotboost?17's Avatar
Nothin Stock
i was wondering if supercharged rims would fit on the turboed cars?
Old Dec 10, 2009 | 07:25 PM
  #48
SSlobalt's Avatar
Only if you clearance the caliper. (grind on it)
I feel sorry for you guys in Buffalo, tonight. I saw the weather report. 0.0
Old Dec 10, 2009 | 07:28 PM
  #49
Nothin Stock
yeah i would try but the other rims are 4 hours away...just wanted to know if anyones done it before i take a trip
Old Dec 10, 2009 | 07:33 PM
  #50
black5spd's Avatar
If you ever wanted to practice drift racing, try your summer tires on the snow, otherwise I would get a sent of winter shoes it is like night and day
