Wtf?!?!
Old Feb 5, 2011 | 11:21 PM
ssball33's Avatar
Wtf?!?!
So I gave it in first shifted into second and then boom check engine light came on and the engine just felt like it was gonna die I made it back to my house. It sputterd all the way there and would give the check engine light when I hit the gas. Even when I let it sit in Idle the rpm's were bouncing up and down. ANY IDEAS?!?!?! The engine just cruising at 3000 rpms in 4th gear was shaking the car back and forth...
Old Feb 5, 2011 | 11:23 PM
Turbo'dSS's Avatar
any aftermarket parts?
Old Feb 5, 2011 | 11:24 PM
ssball33's Avatar
No completley stock.
Old Feb 5, 2011 | 11:26 PM
Turbo'dSS's Avatar
hmmm... My hahn charge piping would blow off of the htrottle body everyonce in a while if i got on it. cor ran like crap when it blew off. CEL just coming on when u press the gas?
Old Feb 5, 2011 | 11:29 PM
ssball33's Avatar
Ya at first the CEL would only come on when i hit the gas then it just started blinkin constantly.
Turbo'dSS's Avatar
guess i should ask is it Turbo or supercharged? lol!
Old Feb 5, 2011 | 11:30 PM
ssball33's Avatar
I had to keep the rpms up high else the car would really start sputtering and shaking on the fringe on dying.
Turbo lol
Old Feb 5, 2011 | 11:34 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
Welcome to cobaltss.net
LOL
My exhaust rattles BAD. LOL
my wheel hub bearing always goes bad..
and my cat is clogged. (boosting 15psi on stock supercharger pulley at the top end of fourth gear)
(need to install new exhaust!!!!!!!)
Just another day in the life of a cobalt owner.
Old Feb 5, 2011 | 11:36 PM
Chevycobaltss3's Avatar
i say umm i dunno dealer bro
gotboost?17's Avatar
Nothin Stock
Do u mean like sputter as misfire?
ssball33's Avatar
It's got 31k miles on it so it should cover everything but wear and tear items like the clutch right?
Old Feb 5, 2011 | 11:37 PM
Turbo'dSS's Avatar
hmmmm... im wondering if something is up with ur MAF, or if a vac line blew off somewhere. have you checked all the charge piping yet?
Nothin Stock
An yes try an make it to the dealer
Old Feb 5, 2011 | 11:38 PM
Turbo'dSS's Avatar
brakes, clutch, ect... yeah doesnt cover wear and tear items like those.
And yeah id hit up the dealer if ur stock. theyll cover it.
Old Feb 5, 2011 | 11:42 PM
ssball33's Avatar
Can't really look don't got much light right now at my APT complex ill check it in the morning.
Old Feb 5, 2011 | 11:47 PM
BlackBeast!'s Avatar
Misfire??
Old Feb 5, 2011 | 11:49 PM
Lol beat me but does it go into boost at all?
Old Feb 5, 2011 | 11:50 PM
ssball33's Avatar
Ya there is boost, but it's erratic gauge is bouncing up and down.
Old Feb 5, 2011 | 11:53 PM
ewwww sounds like a engien internal issue or a bad boost leak
Old Feb 5, 2011 | 11:56 PM
Check intercooler on passenger side end cap for a crack or hole
Old Feb 6, 2011 | 12:04 AM
TommyP's Avatar
AWD > FWD
I agree with black. Check for a cracked intercooler endtank, or cracked/loose charge piping. If it's not that, it's more than likely internal.
Old Feb 6, 2011 | 12:40 AM
G Speed's Avatar
Turbo lol
so unless your car was above let's say 2500rpm? It would feel like it's about to stall?
Old Feb 6, 2011 | 01:11 AM
ATLsilverSS's Avatar
sounds like a major boost leak. I had similar symptoms when my hot side stock piping blew apart...litereallly. was able to drive it home and was gonna take it to the dealer the next day but it would hardly start, I had to keep the revs up in order to keep it running. It eventually died out and I had to have it towed in. Check all your connections and piping for leaks. our ecu will go ape s*** with any type of funky air readings
Old Feb 6, 2011 | 05:59 AM
Nighthawk243's Avatar
I know I'm an SS/SC guy, but I had a Reduced Engine Power last week due to a bad MAP and Barometric Pressure sensor. Take it into the dealer, they'll pull the codes.
Cobalt08LS
Jun 19, 2016 07:29 PM
Getaway_Driver
13
Aug 30, 2015 02:44 PM
Blackey2005
Sep 11, 2011 01:06 AM
