ZFR on stock block
ZFR on stock block
Hello all, soon I will be another person running the ZFR 6758 on my cobalt. I couldn't seem to find a specific amount for a recommended boost PSI. I've seen 26/27 and others at 30 and others at more. ZZP told me that you can go over 30 but I really don't want to blow up my motor.
I have all supporting mods (minus Opel injectors). Those that do run the 6758, what PSI are you at?
I am also at 4300 ish feet above sea level if that makes a difference.
NOTHING has been done to the block or head, just bolt ons.
its all in the tuning. What are your goals for the car?
Modding with a bigger turbo you have to take the risk that something could blow up.
I ran my EFR at all manners of boost from 18 psi all the way to 30 psi.
It depends on how you want the car tuned, boost is just a piece of the puzzle.
However. YMMV...thats the nice thing about the EFR is you can go ***** to the wall or you can tune it for daily and still be efficient and fast
At 20 psi on 91 I made 360 whp 320 wtq. That was great to daily drive around. I was also on stock clutch, motor and transmission at 100k miles. It slipped a bit but not too bad.
You're still around? Assuming from your comment still running the efr and the transmission is ok
