ZZP Silicone Couplers
Has anyone used these silicone couplers from ZZP
ZZPerformance - LNF Replacement Silicone Couplers #ZZ-LNFSILCP and how were they ? Easy to install ? I trust the 90 degree piece replaces the rubber piece that comes off the turbo ? How is the "band clamp" that joins the rubber elbow from the turbo to the plastic piping at the top removed ? I've heard this could be a good improvement because the stock rubber elbow could expand during high boost causing loss of velocity. Sorry for the basic questions, but I'm new to the turbo world and couldn't find just a coupler replacement thread in the How-To section. Thanks for any help. |
I don't know of any part from ZZP that cannot be trusted. I am sure you will have no problems buying any part from them.
Originally Posted by imSLAYER666
(Post 7376903)
Anyone know if replacing the upper rubber coupling will improve performance ? And how the stock band clamp is removed that joins the rubber coupling to the plastic charge pipe ?? |
Youre not going to notice anything different. The zzp parts are just higher quality.
install pretty easy. only thing is the lower stock coupler was pretty tight onto the intercooler. and for the lower one youll wanna be under the car
Originally Posted by Dust SS
(Post 7376920)
The couplers work great. Mine has held boost better than the stock ones.
Originally Posted by tuned08ss
(Post 7376949)
Thx |
They replace the stick couplers, are same as stock except silicon . I got them. Work good. I got the Zfr one, that one is a pain to keep on the turbo, u don't do it just right it pulls out from the tbolt while u tighten and pops off after a few pulls.
Never had a problem with the stock couplers.
If you want an uograde replace the pipes and the couplers. More of a quality improvement mod then a power mod but looks nice under the hood. I wouldn't bother cutting the banding off a shirty plastic pipe to upgrade the couplers which aren't a problem. The pipe is what needs the upgrade. |
Agreed with slap, don't upgrade ur couplers unless u have to. I had to that's why I did. If u don't have to spend the money on something else
Originally Posted by tomj77
(Post 7377066)
I bought them for peace of mind.
Hey guys well i have my couplers since i got the intercooler package from zzp my question is they seem like they have dirt inside like they where in the same place for years and dust just collect it. What should i clean it with? Im thinking just plain water. Also im sure once im getting to installing ill figure out but for now i would like to know what coupler goes connected to what? And last question if i install the intercooler without a tune would it be fine? I know i wont see much of a benefit
just just soap and water,
Thanks tom. Any idea on what coupler goes to what if both are for the hot side or 1 for cold and 1 hot?
Doesn't matter.
When i got tuned the stock couplers kept blowing off the upper charge pipe at the ic. Got the zzp silicone couplers with new t bolt clamps and it's been fine ever since. Highly recommend these.
are the couplers really needed for the intercooler install or can you go without them?
It'll make life a lot easier and will hold better under pressure. Plus you dont need to worry about cutting the stock upper charge pipe couplers.
Originally Posted by sam1031
(Post 7454928)
sorry for the thread jack after an answer please return yup regularly scheduled topic |
I would, its definetly worth it. Looks much better too besides the fact that they work 10000x better than the stock couplers.
options to paint an IC?
just regular paint or powder coat? |
