**TVS DYNO numbers**
As you can see I need more cooling but here you go. Second one shows the torque but for some reason on that one the dyno just stopped recording at 6k rpm.
Mixture was a little rich at low rpms but did not look that bad on the top end thanks Vince.
thats it?
DYNO 278HP 245TQ
^thats all you dynod? i hope that was your first run before it got tuned....
not to upset you or anything but those are very low numberrs for a tvs, im pushing 260whp and about the same as you for wtq and im a 2.4 with 2.9" pulley on 42lb injectors...
my goals on the next pulley will hopefullly exceed what you have here..
id have your car checked out again...
DYNO 278HP 245TQ
the dyno thats reading 278 is somewhat false because its reading in speed not rpm. the dyno reading 265 looks more like it but its a good start , get some cooling mods and get returned
hmmm
good catch.. i never noticed that...
and he's^ righht... you might just need more cooling mods... run some water/meth
Last edited by senior_brown; Mar 17, 2010 at 06:54 PM. Reason: Automerged Doublepost
so you would be pissed that you had the option at any time to run meth and drop the pulley size then put down 325whp+ ? you people bashing it are just dumb, he has the option to move up alot more IF he wants.
jesus
jesus
im not bashing at all.... im just saying that its reallly low and id be upset if it was me....
and then i also dropped a helpfull comment about adding meth/water for cooling and checking over the setup again...
see.. helpful....
see.. helpful....
HOLY CRAP!!! thats some hot iat2s
better make sure your pump is working!
....no wonder
and where's you find a tvs for $1000? sign me up!
....no wonder
Last edited by senior_brown; Mar 17, 2010 at 07:41 PM. Reason: Automerged Doublepost
No spark blow out was straight off the street with one small fan not sure why they did not use the other big one. The IAT2's were at 132 when i pulled into the dyno. I got the TVS used but never installed from the website
....The stock TVS pulley which in 80mm i think?
I see E-85 in my future maybe thoughts
....The stock TVS pulley which in 80mm i think?I see E-85 in my future maybe thoughts
