06g85blackss/pauls new turbo toys :)
#126
Rent me! per hour
ok problem was spike said, no provision for the stock PCV hole, just drilled and tapped the oil fill cap, ran a -8 an elbow, piece of line, to a 1" k&n breather, and all is good.
Now it's running dumb rich, need to figure that out, but I think it's just from the oil going through the exhaust, fucked up the O2 sensor.
fuel pump I'm going with will probably be a Bosch 044, dual return rails, Y fitting, and dual port regulator. Should do the trick. Hopefully I can find something to drive for next week cause the shop can take the car in on sunday
stop waiting for aem. you will be waiting till july for the dbw stuff.
convert the tb and pedal to cable drive and be done with it.
#134
paul u said u had 2 mod ur oil cap 2 run the hahn intake mani........... found this............
http://www.exoticperformanceplus.com....html?item=756
this should make it easy for those like myself going with the hahn intake mani as well
#147
http://www.pfyc.com/pc/GN3020/GNUNDE...er+Filter.html
correction: math>me..........$2 cheaper
#149
$10 cheaper here.
