119 octane!!! WHAAAT
You can with HPTuners
No.
I never said 'drrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr I think he tried to say it turned up his timing'
Jesus you ******* are dense
I said he wasted his ******* money.
You want me to type it larger?
HEY BUDDY
IN CASE YOU ARE BLIND
HAVE IT IN YELLOW
WAY TO WASTE 20 BUCKS
HEY BUDDY
HAVE IT IN YELLOW
i dont know what you think would break. My transmission (shep stage 1 rebuilt) has been tested to over 600awhp in multiple cars and the 4g63 has made well over what im pushing. Getting to third gear would be pulling into McDonald's an 1/8th mile ahead of you down the road. Come back when you run 11's. You need to re-read what i said about the gas and accept it as fact because it is one. You can argue it all day but it's like arguing that the earth is flat. You are wrong end of story.
It really doesn't even matter what you are trying to say. I explained to you EXACTLY why you would ever use higher octane gasoline and you said i was wrong. That is proof enough to everyone here that you have no clue.
exactly
hmm i know the 110 n 112 sunoco race gas around me is leaded... fuel cells. eh. gehy
Last edited by o3nisoaso3; Dec 10, 2008 at 12:53 AM. Reason: Automerged Doublepost
ok guys, settle down.
not everything over 94 octane is leaded, if i cross the border into sumas washington i can get 100 octane unleaded at the pump. pretty much anything over that is leaded though.
now, upping the octane is only useable if you tune for it. popular hot rodding just did a dyno test on a zz4 crate motor (350 chevy, around 350hp to 400hp iirc). the motor was designed to run on pump 91. they dialed it in on 91, then bumped up to 100 unleaded, gaining nothing. they tuned the motor for optimum power and gained 7hp. they then put it on 116 octane leaded fuel, and even after dialing the motor in they had lost power over the 91 octane setup.
i posted my above info cause people seem to need proof.
while the lead is a pro, the more then likely ogenated fuel mixture your running now is alllllll bad.
if i was you, i'd be in a bit of a hurry to learn what effects "high octane" fuel have on engine thats are not adjusted or prepped for them.
it can get ulgy in a hurry.
the lean condishion is most likely caused by a pre-oxygenated fuel, its vary common to run across as these octane levels, and unless you've got injector control, things go bad fast.
if youre an octane junky, for any of a number of reasons, stick with better known fuels.
such as Torco 110, turbo blue 104, ect. VP also makes some fantastic ****, its used on almost all our development engines because you can get an un-oxygenated fuel at 126-128 octane.
vary hard to destroy a motor on a fuel that doesnt want to burn.
Unless its been said already! Lead clogs cats, and kills O2 sensors and can damage other sensors if it comes in contact with them. Cats can't burn off the lead and they get clogged.
*DISCLAIMER* If someone has already said this then please disregard this post. Thank you.
According to the calculations of the fuel calculator. if you blend 2 gallons of 119 octane with 93 octane gasoline. You are running a mix of 97.33 octane.
http://www.ranney.com/mjr/fuel_blend.html
