12's
personally i would say dont go for 12's until your comfortable in the 13's
these cars are not easy to launch. I would go with a middle of the road setup, something around a 2.9ish pully (stage 2 possibly) get some slicks/DR's and some solid mounts.
Go to the track and get yourself into the 13's with consistancy.
get used to how picky this car can be at the track.
THEN pour the money at the engine.
just my 0.02c
just my 0.02c
I agree!
I was thinking...
"Rob's Cobalt has the INTENSE stage3 kit, Corsa Touring cat back exhaust system, and the INTENSE oversize tensioner pulley He dyno'd 270WHP and 236WTQ with just the stg3 kit and recently dyno'd 276 WHP and 258WTQ with the corsa and a 2.6" pulley. Rob recently accomplished his goal of being the first street Cobalt into the 12s with his best ET on 4/5/06 a 12.940@106 w/ 1.82 60' and he plans on improving that dramatically this year. "
from intense.
The Stg 3 is 529.99, and I'm sure with the left over $3400 you could find exhaust and a tensioner plus some extras.
from intense.
I will have... 2.6 MPS, Vibrant Header/DP, intense TA mounts and JCB CAB (just installed those 1 hour ago), Exedy clutch(that COMES with the FLYWHEEL), 60 lb injectors, oversized tensioner pulley, interceptor guage, and wideband...... I just need some slicks and axles now!!!
1. Bully Clutch Stage 4 6-Puck kit $659
2. Driveshaft Shop Axles $700
3. Intense Motor Mount Bushings/CAB's $259
4. TAG Stage 2 Kit http://tagracecraft.com/Package.html $1150
5. Corsa Touring 2.5" catback $650
6. ZZP header and downpipe $439
7. NGK Wideband Gauge $220
TOTAL $4077
This is pretty much the cheapest way I can figure out how to get you in the high 12's. This however does not include a set of drag radials you will need. You can do the airbox mod instead of getting an intake as well for another $40.
TOTAL $4077
keep in mind, the mounts may cause too much vibs and may set off yer knock sensors, this happened to me, so the mount is off and a brace is being developed by tag that is adjustable and will not bend, ive got 60's and a 2.7, a insane tune from tag and a onslaught of bolt ons, gonan do the dual pass plate , axles and dr's and ill see what the car does
