15psi
Old Oct 11, 2005 | 06:12 PM
mcz34man's Avatar
15psi
hey guys i did a pulley swap this weekend to a 3ini have a custom intake with a high flow filter, and i have a custom 3 in cut out with a performance muffler.
went out on a country road the other day and got it up to 15 pounds, next time i will take me camera for all to see
Old Oct 11, 2005 | 06:19 PM
BlAckOnBLaCK's Avatar
Could you feel a difference with the new pulley? What brand pulley did you go with?
Old Oct 11, 2005 | 07:17 PM
VaMP's Avatar
I guess you switched the guages? Since the stock Cobalt one is unable to go past 12.5
Any dyno results?
Old Oct 11, 2005 | 07:23 PM
Waylin22's Avatar
hhmm...y cant the guage go past 12.5 psi?...will a new guage come with the staged upgrades to calibrate this?
Old Oct 11, 2005 | 07:30 PM
Jmc007's Avatar
I run the stock gauge with the 3" pulley and it always show 14,5 PSI near redline ! The by-pass mod must be done, because the PCM limit the boost to roughly 12PSI. That's why the stock gauge always show a max of 12 PSI near redline without any mod but smaller pully.
Old Oct 11, 2005 | 10:06 PM
eastcoastz's Avatar
Can you feel the gain in power?
Old Oct 11, 2005 | 10:14 PM
Jmc007's Avatar
I got my car dynoed for a 15 WHP gain and and about 13 to 15 ft-lbs torque gain; for sure I feel the difference ! My wheels are now spinning in 2th gear on rainy surfaces too ...
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/3-0-pulley-technology-pulley-dyno-results-5914/
Old Oct 11, 2005 | 10:19 PM
mcz34man's Avatar
I havnt switched gauges yet....its still stock, but i POSITIVE it was at 15psi when i get time this weekend i will post picks, since its kinda hard to hold a camera, shift, and stay on the road...so my buddy will ride along
i can definaltly feel the power gain, blower wines even louder!! I got the pulley from pully technologies, easy to remove the old and install with their fool proof puller.........so until the weekend!
Old Oct 11, 2005 | 10:29 PM
eastcoastz's Avatar
How was it removing the blower? It looks like only 4 alen screws bolt it on to the manifold/aftercooler.
Old Oct 11, 2005 | 10:33 PM
JoeyCobalt's Avatar
2nd gear spin in the rain? ,hell i was coming home in a light mist tonight and was getting 3rd gear spin at 120 KPH! NICE!
Old Oct 11, 2005 | 10:46 PM
Fast Freddy's Avatar
removing the blower is a blow. I just installed a 2.85 pulley and new tensioner took approx 45mins for total install.
Old Oct 12, 2005 | 12:02 AM
Did you buy the pulley puller? Can you rent that sucker? I really don't want to spend the extra money for the tool if I don't have to. Also, Once the pulley was installed did you need to reset your ECU buy unplugging the battery or is that just a waste of time? Thanks
Old Oct 12, 2005 | 03:09 PM
mcz34man's Avatar
florida pulley headquarters says your supposed to reprogram with a 3in and smaller......no problems here. Spend the extra money and get the puller from where you get the pulley, trust me it is worth it. Whatever you do dont use a 3 jaw it fudges up your old pulley massively. Removing the supercharger wasnt hard at all.
From memory:
take of belt by prying down on tensioner. Losen or take of air intake hose, unplug/pull all tubes going to the s/c, remove coolant hose--prop upright so you dont spill any. then unhook 3 electrical plugs one on right side of s/c, another behind the s/c (by fuel rail), and the hardest one is underneath the s/c.
TIP: when putting the supercharger back in put all the allen bolts in the holes on the s/c, put the left bolts in first, lift up on the right of the supercharger, put the belt on with ease then draw the supercharger down with the allen bolts on the right side (you have to hold it down to then start them)
I highly recomend taking the s/c out of the car instead if tryin to swap a pulley with out disconnecting anything.
Old Oct 12, 2005 | 05:22 PM
Cool
From memory:
Thanks!!!!! Once I get my motor back I think I will put one in.
Old Oct 14, 2005 | 01:10 AM
zinner's Avatar
Moderator Alumni
I am gonna confirm seeing 15 PSI with a 3 inch pulley via the ECU. I don't have the stock boost gauge hooked up anymore cause I have the Interceptor OBDII gauge, but I was seeing 14.2 psi via the gauge. You would probably see 15 if you took it to the redline.
At this point I think the 3.25 inch pulley really isn't going to add any performance.
Old Oct 14, 2005 | 09:36 AM
SuperchargedSS's Avatar
I can burn rubber in 2nd on command
TheSandMan
Sep 20, 2015 06:02 AM
Jmc007
Sep 11, 2011 10:16 AM
vtecduster
Jul 24, 2007 11:56 AM
AROON02
Mar 8, 2007 09:38 PM
crazyffrey
Apr 18, 2006 03:02 AM
