2.0 Ecotec motor cut out at full throttle.
I have an 2006 cobalt ss with stage 2 upgrades, 2.8 pulley and bigger injectors and a reprogram of the computer running 15 pounds of boost and 93 oc fuel. when I hit full throttle the car cuts out on me. what could this be?
Spark Blowout? Check your plugs.
Also check your DTCs. (Diagnostic Test Codes)
You can have them read at autozone if you don't have a reader yourself.
Also what stage 2 setup are you running?
GM Stage 2 (42lb injectors) + 2.8" Pulley = Maxed out Injectors...
I just got the car last week so i never checked the plugs yet.
Also no codes come up and this problem doesn't happen ll the time.
And I also dont know what injectors are in there but the guy said he did the GM stage 2 setup to the car. If i was running with 42lb injectors and a 2.8 pulley what do i need to do?
What do you mean it cuts out?
Like the engine quits running?
Is it only one pop? Does it happen at the same RPM all the time, or vary?
Just saw that you are local. By any chance is the car yellow?
Ok so I just looked at my pulley and it says 78.0 on it witch is a 3.06in pulley with 42lb injectors so with that said why would it be cutting out at w.o.t?
i have a 2007 cobalt ss supercharged and mine just recently started doing the same. at the end of gears before i shift it sputters and the boost gauage flutters from 10-16 psi at wot then ishift it goes normal till the end of the next gear? ive checked plugs, new fuel filter everything. mine is completely stock other than zzp 3in intake thats it?
I have the same stuff done to my car too and its orange with the g85 package. But when i do go w.o.t the car starts to sputter and when i let go of the gas it is back to normal...
All good thoughts, but get this one...I think this is happening to me only when my gas tank is low. I also think that the fuel pick up is in the front of the gas tank so when i get on the throttle all the gas goes to the back of the tank and does not pick up any fuel. I filled up today and i dont have the problem any more
Cause, the smaller the pulley you go then not enough fuel to cover the amount of air that is forcing into your engine. Your fuel injectors are maxed out at least the most is 3.1 that what it said on ZZP site. If I were you go research on ZZP site you will find the answer that you are looking for. As of right now I would be DAMN careful with 2.8 and 42lbs. It's not safe, you can end up fried your fuel injectors.
