2.0 LSJ Head, Cams and valve information ...
Old Aug 3, 2007 | 06:41 PM
elecblue06's Avatar
they have a 300 hp build book... which is part of the reason i find it so funny that so many people are saying that you can't hit 300 hp... but i've never seen a 400hp build
Old Aug 3, 2007 | 06:48 PM
shawns94's Avatar
Originally Posted by Maxim_X
Didn't the GM sport compact build a 400 horse LSj on stock heads?
Stock head you mean. I am not sure but the did build the 300hp engine with the a non ported head although they had to up compression and almost completely upgraded the valvetrain. I am not sure that it would be possible to build a 400hp lsj with the stock head.
Area47's Avatar
Rent me! per hour
with nitrous in the time attack car.
Old Aug 3, 2007 | 06:49 PM
shawns94's Avatar
That setup is for racing only and will not work on the street.
Old Aug 3, 2007 | 07:02 PM
SilverSS/SC's Avatar
Theres lots of people that have hit 300 bhp . The GM 300 build is bhp , not whp .
Thanx for all these flow #'s Jcm007 . Ive wondered for a while what a stock LSJ head is worth cfm wise ...I can now justify buying a spare head to play with
Once youve moved on from the heaton its possible .
Last edited by SilverSS/SC; Aug 3, 2007 at 07:02 PM. Reason: Automerged Doublepost
Old Aug 3, 2007 | 07:14 PM
Area47's Avatar
Rent me! per hour
100 shot
Old Aug 3, 2007 | 09:07 PM
elecblue06's Avatar
huh I didn't realize it was BHP, since they say take it from 200 hp to 300 hp i guess that was my fault assuming considering the lsj's are underrated
and shawn how was it "for racing"? yea they nixed a few things that would compromise ride comfort but i didn't think they had anything in there that wasn't streetable
Old Aug 3, 2007 | 09:28 PM
Originally Posted by Area47
100 shot
Not disagreeing with ya there , hehehehe
Old Aug 3, 2007 | 10:57 PM
Jmc007's Avatar
http://www.compcams.com/Information/...ECOTECCams.pdf
http://www.compcams.com/technical/Ca...12-117_226.pdf
Old Aug 4, 2007 | 12:52 AM
Onyxd04Redline's Avatar
They don't work with the LSJ
Old Aug 4, 2007 | 01:26 AM
  #36
Jmc007's Avatar
It's probably WHP ...
https://www.cobaltss.net/gallery/sho...imageuser=2736
I need porting !!!
Old Aug 4, 2007 | 01:33 AM
  #37
Rodimus_Prime's Avatar
sadly at this time theres not an affordable aftermarket cylinder head all thats out there is the jbp which is way over priced, too bad theres not a patriot head out there
Old Aug 4, 2007 | 01:39 AM
  #38
Scythe_Snake's Avatar
Sorry for a silyl question guys, but:
Okay, are P&P head and ported head the same thing? P&P=Ported Polished?
The head is everything above the pistons (cams, valve springs, crank shaft, etc?)?
And is the GM head just as good as getting a race ported head at a shop?
Originally Posted by whitted2268
These are my next mods=), through JBody
I've heard nothing but bad about JBP, but they are the only ones with race proted heads? And what about their wild crate engines? Don't those do it for you already?
Last edited by Scythe_Snake; Aug 4, 2007 at 01:39 AM. Reason: Automerged Doublepost
Old Aug 4, 2007 | 01:40 AM
  #39
I was almost banned the last time i talked bad about a sponsor so i will just say this....
OVERPRICED!!!!!!!!!!!!!!!!!!
Old Aug 4, 2007 | 02:04 AM
  #40
I just looked at it. It is extremely expensive.
http://www.jbodyperformance.com/new/...catName=JP0940
It seems REALLY good, but that is more than the TS Swap is. that should be cut at least $600+
Old Aug 4, 2007 | 02:13 AM
  #41
Doc's Avatar
Doc
I'll agree with you..
Old Aug 4, 2007 | 02:19 AM
  #42
Originally Posted by PuSha050
P&P head....$1000.00
Valve Springs and Ret....$400.00
Cam Regrind.....$300.00
10.0:1 Pistons Cer top.....$625.00
Intense Shorty Header.....$400.00
Custom 3in Cat back.......$300.00
Exedy Clutch....$1100.00
the 10.0:1 Piston thing, are those Ceramic Toped (Cer top?)? And why 10.0:1?
Old Aug 4, 2007 | 02:20 AM
  #43
lsjwannabe's Avatar
you lose some compression due to overlap from the aftermarket cams and the ceramic coating is for protection against heat i believe
Old Aug 4, 2007 | 02:27 AM
  #44
Ah, alright. I was looking at the 2.0LSJ WILD build on JBP as well. For the wild build they only use 8.5:1 or 8.0:1.
http://www.jbodyperformance.com/new/...catName=JP0912
But I see it now with the MILD build. They offer the 10.0:1 comrpessions.
http://www.jbodyperformance.com/new/...catName=JP0916
Hm. Mild Crate Engine + Stage 3 Cylinder head = Big HP? (Also an empty wallet)
http://www.jbodyperformance.com/new/...catName=JP0916 -(MILD Crate Engine)
http://www.jbodyperformance.com/new/...catName=JP0940 -(Stage 3 Cylidner Build)
Old Aug 4, 2007 | 02:36 AM
  #45
DrPuttsSS/SC's Avatar
One of the things about this forum is that so many members are young and inexperienced with basic performance concepts and don't yet know how all the pieces fit together to make a big power motor.
With this thread I'm sure there are some young kids out there with stock 2.2 Balts that are now convinved that they need a $1000 port & polish job done on their head!
We must keep perspective, the more experienced guys know that. There is a whole list of things that should be done to their engine before someone needs to worry about the flow rate of their head because the stock head flows pretty well, compared to older designs.
For example, lets say I've got stage 2, CAI, headers and 2.5" exhaust, what, maybe 260HP, how much HP would I get from a $1000 head job? I bet it wouldn't be very much, maybe 10 HP, and by slowing the velocity of the intake air it would probably move my torque curve farther up the rpm band so I'd lose some low end. Some people who have paid to get their heads ported have gotten no advantage, no more power.
I always advise people to leave the head alone until you have to open it up. In other words, when you've bolted on enough external power equipment that the head is holding back your performance, then it is time for a P&P.
So what do you experts think? You probably need a ported head when you approach what, maybe 300WHP? Seems to me that any less than that and the money would be wasted.
But of course the guys going for absolute max HP need the head work, and the cams, and the springs for your high RPM monsters!
You know, I just had an idea for a spreadsheet. I wish we could put together a sheet listing the power increases people are getting compared to the money spent. We all want the most for our money, right?
For example:
Part: Price: HP Gain:
Stage 2 Kit $550 XX.X HP at XXX RPM
Oops, hit the submit button.
Again, I wonder if we can make a spreadsheet like that, especially showing how different parts add up to increase gains.
Just my opinion
Randy
'05 Yellow SS/SC
Last edited by DrPuttsSS/SC; Aug 4, 2007 at 02:36 AM. Reason: Automerged Doublepost
Old Aug 4, 2007 | 02:44 AM
  #46
For example:
Just my opinion
Randy
'05 Yellow SS/SC
Good post. Just FYI, I wasn't thinking of doing this. I am just trying to learn about engines in general, specifically the LSJ. I'm not going to P&P my head. Of course if you por and polish the head too early when you don't need it, your powerband is going to get all freaked up. And yes, I am a young guy who is inexperienced with the basic concepts, and the only way I can learn is to ask, and post.
The problem I see with the spread sheet though is every car is different. Some people stock dyno between 210-220whp. Some people slap on mods and get different numbers.
Old Aug 4, 2007 | 03:41 AM
  #47
You show wisdon beyond your age! You're right, hog out the ports before you need it and all you do is really screw up the low end performance of the engine. Guys with carbs can really cause problems with uneven fuel atomization and things like that. Cams are like that, too, BTW. I've known guys over the years that thought "bigger must be better" and threw high lift cams in their motors and then couldn't get it to idle at less than 3000rpm. Useless on the street.
As far as the spreadsheet, I would just try to get an idea of average gains for the parts. Each engine and part are different but if enough people donated data we could get a good idea of what each part would do. Now that I think about it more, maybe tomorrow I will start making up a sheet just using the manufacturer's claims. Wouldn't be very accurate but would get newbies an idea of where to put their money into mods.
Something like: Stage 2 Kit, $550, 25HP, = $22 per HP gained.
But again, the more I think about it the less probable the sheet would be. I know that when I build my Balt over the winter I will most likely just install and mod everything at once before putting it on the dyno for a tune.
Randy
'05 Yellow SS/SC
Old Aug 4, 2007 | 04:59 AM
  #48
ItalianJoe1's Avatar
Good info. This goes with what I have said all along, one of these cars can make good power if done right, I think low 300s on the stock blower without running a 2.6 or smaller pulley is very possible, but you have to deal with the restrictions as you come to them. I will have to do a head eventually, my goal is to be at a solid 350 to the wheels, with a strong enough engine to spray and additonal 100hp shot on top of that, for emergency use only. I think with a proper build it can be done with the Eaton. I still may end up with a twinscrew though, depending on what people get outta some of these new kits.
Old Aug 4, 2007 | 12:11 PM
  #49
Jmc007's Avatar
Here is one ;
http://www.m2race.com/product_specs.asp?ID=5#
Old Aug 15, 2007 | 02:05 AM
  #50
Jmc007's Avatar
Important : Post Number 1 edited.
Also read this :
http://www.year2032.com/ecotec.pdf
Question : What am I ?
https://www.cobaltss.net/gallery/sho...=3&userid=2736
Answer : The absolute biggest bottleneck ever on the LSJ ...
