2.8, meth, 60s.. Advantages over 2.9 with 42s?
As the title says, what are the advantages if I was to buy 60s with a 2.8 and a basic meth kit? What kind of additional power can I expect? Would it be worth the ~500 dollars for the upgrade? Thanks for any info.
Theres been alot of threads about this lately...
Smaller pulley = more power.
Meth = Cooling + Efficiency (Power)
If you are planning on doing any more than a 2.8, NO... You can run a 2.8" with 42.5s espicially if your running meth.
If you wanna end up running a 2.6 or something, and you overall would like more power, Then the 60s would be the way to go.
From what I have gathered, it's not the heat issue when it comes to a 2.8 with 42's. It's the fact that the injectors are past maxed out. My injectors (42's) were running at 110% IDC on the GM stage 2 tune.
a return fuel system isnt necessary for a 2.8" and 60s. not until you go TVS or turbo is that necessary.
I also am debating on whether to go with methanol for my 2.8" and 60# set up. I have a front mount h/e but my iat2 still hovers in the 135-140 range after a 1/4 mile pull in the summer time. (i dont beat on it when its cold)
If you're running a 2.8 on 42s, I guarantee you that your IDCs are over 110 and if they aren't, your car is leaned out way too much..
you IDCs will be a lot less obviously with the 2.8/60s than with the 2.9/42s. also the meth will help reduce your knock if not eliminate it all together, plus add a little reliability and a slight power increase. you could possibly run a 2.8 and keep the 42s if you were to run meth. but personally, i wouldn't. so IMO, an upgrade to 2.8/60s/meth/retune. is worth the money
hmm, seems a little weird to me. first gear puts virtually no load on the car since its over so fast. The two biggest oplayers for power on these motors are timing and afr. When you tune a car for less power generally its a more rich tune. That the reason for asking for the pw, that way you can see if his pid was off for idc's in hpt.
