2.8 pulley 42.5# injectors
If your on a stage 2 tune, its absolutely stupid. The tune is horrible and your idc's on any tune will be through the roof and you will be static. You need 60lbers and a good solid tune. Not even to mention cooling mods. Without any cooling mods your iat2s will be through the roof.
Haha, Lol! Altitude will play a big roll on this subject too. Some guys in Colorado are running the 2.8 on 42.5's with no trouble and are not static. I know of a guy running stage 2 + 2.9. Seems to have no trouble and he is a very good mechanic. I trust he knows what he is doing.
Jesus will say he hates you.
But seriously...you're boost will get higher by about 2 psi (from 2.9) but your injectors will or will not be in cahoots with Jesus (in saying they hate you). Really...truly...honestly...it does nothing to hurt a daily driver. Us idiot redline trial and error guys have run 2.8's for a long time across the country and there was a dude that hit over 30k miles without any engine problems or injector problems so...if you don't go over 6k in each gear most of the time I say go for it. I ran a 2.8 for about a year and a half on the s2 tune (15k miles roughly) no problems at all, I run a 2.9 now only because my 2.8's bolt holes got stripped when I was swapping pulleys.
I've run a 2.7 short term and it's fun but not something I'd do more than 100 miles at a time.
like stated before, it's all in the tuning.
i run at the leanest 11.7 afr on my aem uego wideband, and logging shows that my pulse width and idc's are in the safe zone
oh, and max for 42's is not 120%, it's 100%. anything over 100% is taking the injectors beyond their intended capabilities
however, you still want a safe zone, like say a 20% buffer, just in case
i have a 2.8 with 42.5s...
Stage 2 tune i heard is bad to use with a 2.8 pulley..
I have a custom tune... If you can get one of these (a good one).. i wouldnt go under 2.8 but its doable...
ONLY with a custom tune... stage 2 tune = no good...
k?
k?
#1 maxxing out the 42.5# injectors
#2 taking the blower out of its efficiency range (per eaton, the reccomended pulley size for efficiency is 2.8)
