2.8 pulley with 42.5 injectors??
ya some1 told me about u. how much? i was leaning towards a 2.9. Now the one thats on the car now is the intense one. I just bought this car and i should be getting this car this week. But would like to replace the pulley. Intense sells the 2.9 for $60
To the original poster, I would stick with a 2.9" to be on the safe side.
in my opinion, a 2.8" pulley with 42.5lb injectors should be perfectly fine. just make sure you have some way to get it tuned properly. otherwise you will run like crap. i had a 2.85" pulley with those injectors and ran fine with room to improve.
I talked to CA today and they said its perfectly fine to run their 2.79 pulley on the stage 2 as long as your not going to run the **** out of it. They said 60# injectors was overkill especially if its a daily driver.
What's your reasoning for having it look like the Stage 2 pulley? If it's for warranty work I'd suggest swapping the stage 2 pulley back on before taking it to the dealer for work. If it's for racing, you can paint it black if you want to make it a bit more inconspicuous.
did u get my email???
ya well some1 told me that i do not need to retune car if i replace the pulley. that i only need to retune it if i replace injectors. U dont need to criticize my question, since im new with all this!!!!!
However, when you change injectors, this is why you need to retune. The PCM still thinks you have the stock injectors which flow at a certain rate. Your new injectors flow at a higher rate. The PCM uses percentages. If, say, at WOT (these are just made up numbers) your injectors are running at 50% and flow say 550 cc's, then approx 275 cc would go through. Say now your new injectors are 750 cc and your PCM sets your injectors at 50% again at WOT, you are not at 375 cc. This is an extra 100 cc of fuel! This is why you need to retune.
In summary, if you swap your stock pulley for a 2.8", then your car may run, but chances are it will run like poop and perhaps go into limp mode, or reduced engine power, whatever its called. With a proper retune, you may be able to run your stock injectors, but I would advise against it. You definately want to get the 2.8" pulley with 42.5lb/hr injectors and the new plug'n'play harness for them. If you want to tune yourself, just pick up a MAF-T and a Wideband. Otherwise, find someone who can tune it for you. Good luck and happy modding.
let me clarify this 1st, right now i currently have a 2.8 with 42.5 injectors. Its been tuned by INTENSE. Im thinking about putting a 2.9 pulley in, instead of the 2.8 to be on the safe side, since ive been hearing lots of probs with the 2.8 with 42.5 injectors. So since my cars been tuned already with the 2.8 if i put on the 2.9 do i haveta retune it?
It's not just about 2.8 / 42.5 # injectors, but also what other mods are on the car.
Someone with just 2.8 and injectors will probably run fine without any problems. Take someone else with that plus, intake, gutted exhaust, ported blower, etc. and you'll be more likely to run into problems. Also, air density (affected by temperature, elevation, etc) will play a large part as well. If you're really worried, either stick with the 3.0 and 42.5, or find a way to datalog your car and see exactly how much you're stressing your injectors.
my IDC is typically high 90's at the top end, but my AFR is in low 12's. I depends on how you have your PCM setup to control the fueling, typically with Piston Protection and Cat Over temp *ON* your PCM will command 10.8 AFR and so 42# are WIDE open and your IDC is 100+
Sure you can go for 60's but IMO you don't need to if you plan to stick to a 2.8.
BTW I have a header back 3 inch exhaust and K&N filter.
As far as i was told by the intense guys was the 2.8 would work with the 42.5 from the stage kit but they recommended reducing the 7000 redline back to 6500 rpm to be safe... that was with the GM stage 1 tune.... Now if you run a custom HP tune thats a different story.
I went with there advise and got the 2.9 but i am retuning soon and will switch to a 2.8 and keep my 7k redline
