2.8 question
Old Jul 6, 2006 | 09:52 PM
cblt12's Avatar
2.8 question
ok well i just bought a 2.8 pulley bc i got a good deal on it and now im undecided on what to do next... i know everone is going to tell me to get hp tuners but i dont really want to spend that much and it would get me into trouble... anyways i was wondering if it would be ok to go w/ the intense s4 pcm and 60 lb injectors or just stick with s3 w/ 42's with colder plugs of course?
Old Jul 6, 2006 | 10:06 PM
cblt12's Avatar
bump... i know someone has to have an opinion
Old Jul 7, 2006 | 09:23 AM
rnjmur's Avatar
I would just stick with the 2.8 and 42.5 with colder plugs. It seems to work well for everyone else.
Old Jul 7, 2006 | 05:27 PM
cblt12's Avatar
but i need a new pcm too and that is more what i was wondering about
Old Jul 7, 2006 | 05:36 PM
Shortbus's Avatar
Just get a custom tune, with 42.5lb injectors, colder plugs, or you could get the s3pcm, but you would get more out of a custom hp tuner tune, becuase you can always change it, and adjust settings when ever you want.
Old Jul 7, 2006 | 05:39 PM
cblt12's Avatar
ya i kno hp tuners is the best way to go but its ****** expensive
Old Jul 7, 2006 | 05:43 PM
Matty's Avatar
No matter what you do, that pulley will require bigger injectors...hence a PCM adjustment.
If you go stage 4 then it is an even smaller pulley than the 2.8 you have.
Stage 3 is a bigger pulley.
Find someone in your area that has an HPTuner and who knows how to use it, and give the guy(s) a few bucks to tune it with 60# or 42.5# (your choice)
Cheapest way I can see.
Old Jul 7, 2006 | 08:12 PM
cblt12's Avatar
thanks but there are actually very few ss/sc around me espically ones that are looking for hp tuners. but anyways i kno that i am going to need bigger injectors but my question was w/ my 2.8 pulley should i run s3 pcm w/ 42's or should i run s4 pcm w/ 60's
Old Jul 7, 2006 | 08:18 PM
SS33's Avatar
Aren't people were getting away with running GM stage 2 and the 2.8
Old Jul 7, 2006 | 08:36 PM
cblt12's Avatar
ya there are a lot of people running the 2.8 with the stage two but i am trying to hopefully get more than that out of intenses products for probably less money than stage two
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
SlowSaturn
Sep 28, 2015 11:03 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
