Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   3.5" Intake (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/3-5-intake-307159/)
Josh@ottp Feb 19, 2014 01:01 PM
3.5" Intake
Who would want one and would you just want the lower pipe to be 3.5" or the whole intake to be 3.5"? I will be mocking on up today and was just curious.
Hockeyman Feb 19, 2014 01:05 PM
I'd be interested if the whole intake was 3.5", plug and play with the LS4 TB and TVS.
jrmotosports 88 Feb 19, 2014 01:10 PM
click
blueLNFftw Feb 19, 2014 01:23 PM
I would be.
Think it will fit through the hole in the frame without cutting it up?
My RD Fabs one fits pretty shifty.
KMO43 Feb 19, 2014 01:37 PM
This for LNF or LSJ?
ECaulk Feb 19, 2014 01:41 PM
...Seriously?
Josh@ottp Feb 19, 2014 01:55 PM
Originally Posted by BlackSSstg2 (Post 7277738)
I would be.
It fits with about a 1/4" around the sides. For the best fitment I would most likely trim a little towards the front of the car to push the intake away from the tire. At the very least I would put some hose on the car to stop any vibrating of the intake.
06cobaltncng Feb 19, 2014 01:59 PM
im still rocking the stock airbox. been debating changing but I think itd only be for looks.
KMO43 Feb 19, 2014 02:11 PM
Originally Posted by ECaulk (Post 7277754)
...Seriously?
sorry didn't read section I want a better cold air for my LNF
yellowsupercharged06 Feb 19, 2014 02:19 PM
id buy one, pending it isnt overkill
some dyno sheet of 3 vs 3.5 would be nice too once its mocked up
mrbelvedere Feb 19, 2014 02:28 PM
get real its not going to happen
I would do a lower or a whole if It fit without cutting up a bunch of shit
yellowsupercharged06 Feb 19, 2014 02:30 PM
whats not going to happen ? and what am i getting real about ?
Staged07SS Feb 19, 2014 02:32 PM
A dyno of a 3" vs 3.5" intake.... that's what mrb was getting at.
This intake is only going to benefit TVS cars with extensive mods to the engine.... ie. a ported head, cams, additional power adders such as nitrous, etc.
A stock engine M62 or TVS car will see minimal if any gains from this.
mrbelvedere Feb 19, 2014 02:32 PM
someone doing a before and after test on the intakes is not going to happen so I recommend you do it
yellowsupercharged06 Feb 19, 2014 02:36 PM
i mean if Josh is going to produce one, why not put the time and effort into it ?
sooo we should all just buy one cuz its bigger ?
where is the logic ?
he asked about interest, i gave my interest and reasoning .....
would you buy a tvs if you had no idea if it was going to be better than an m62 ? or would you want harrop to show you it was better before your said ohh yea ill take one ???
Josh@ottp Feb 19, 2014 02:39 PM
I would like a test dummy for one.
Bluelightning Feb 19, 2014 02:41 PM
How many products do you see for our cars with before and after results that a manufacturer does? Veeeeery few.
yellowsupercharged06 Feb 19, 2014 02:43 PM
looks like Josh is trying to though...
Hockeyman Feb 19, 2014 02:43 PM
I'd be happy to :twothumbs
But the TVS isn't going on until springtime.
WVU_SS Feb 19, 2014 02:44 PM
Same here. I'd test one, however I don't really have the mods to make it worth it right now.
Josh@ottp Feb 19, 2014 02:44 PM
I think a few guys are missing the point of this. Not only will it make more power on a high end build, it is basically going to be required with where we are going. 375whp on e85 is more than enough power to overrun the maf table. Only way to get back on it is to go to a bigger tube for the MAF sensor.
blueLNFftw Feb 19, 2014 02:46 PM
Hi, I am corey and have done one of these for you before.
What do you need from me?
PM or email.
yellowsupercharged06 Feb 19, 2014 02:51 PM
Advise is a good friend of mine, he is in this area and he may be interested in testing this out for ya.
Tjolley Feb 20, 2014 07:13 AM
More then happy I can do u one better i have zzp 3" cia, inner cia, k&n typhoon cia, aem, stock. All sitting on the shelf at home.
Wouldn't take much to swap them all out at the dyno. Just show up with no fender liner. I can do it on my 2.4 and 100%meth(steve) can do it on his 2.0
Proly dial in ur 3.5 on the street first since it takes so much manipulation of the maf table.
MrSlickSter06SS Feb 20, 2014 10:43 PM
Wish I was local to you I'd let you have the car for a bit to play around with. Where would you locate the MAF sensor on the Tube? I am skittish since my Injen caused idle bounce do to poor location of the MAF mount, at least that's what I believe seeing's how going back to my stock air box, and doing an air box mod corrected the idle. I believe, correct me if I am wrong, ZZP said the MAF was seeing to much turbulence within the tube rather then a nice flow threw the tube..? Just curious is all, o and I don't have a TVS so I clearly wouldn't be a good test subject unfortunately.. Anyone close by should jump on this.
