300whp+++ Here I come!
Old Nov 7, 2006 | 06:39 PM
BoomInIt's Avatar
Originally Posted by djt81185
how arae u going to run those low impendance injectors with the cobalts stock high impendance setup?
I guess they can figure that out for me since my specialty is car audio & custom fabrication. I trust them to build it correctly I know numerous people that have had great tunes/work from Futral.
Originally Posted by SilverSS/SC
Futral puts out some good stuff . Good luck with the build .
Many in the LS1 community are familiar with Futral. My brothers Zo6 had work done there 450whp and once again... engine swap to 383 500whp+ all motor. They just put out a turbo Candy Escalade on 24's that runs 10's. It is a Saints players SUV.
Originally Posted by 2K5SS/SC?
Good choice on the mods. EXTREMELY BAD choice on the Headgasket! If you are getting the O-ringed gasket, your block is going to have to be machined for them. It's a waste of money. The stock gasket is just pure ****! Go with a Cometic headgasket as they have an excellent reputation for high horsepower builds, worked great on car, and you don't have to machine the block for them! Good luck on the build, and I can't wait to see the results!
Says its good till 450hp. Guess we will see.
Old Nov 14, 2006 | 01:39 PM
Rogue's Avatar
Originally Posted by Blown 4-banger
An O-Ringed head gasket will hold like 100 psi! How is it a waste of money!?!? Its like impossible to blow an O-Ringed head gasket!
While true, you must also think this way. The gasket is like a safety valve. If you cant blow the gasket what are you going to blow?
Old Nov 14, 2006 | 03:48 PM
2K5SS/SC?'s Avatar
I'll admit the O-ringed gasket is better if you're going for huge PSI numbers, however for the power range most of the builds are dealing with it is highly unecessary. The Cometic gasket I have required no machining, and has been proven time and time again. My buddies drag car has 1300+whp all motor, and he's rocking Cometic headgaskets just like the ones in my car. All the drag car guys around the lowcountry rely on them, so I decided if it works for them it'll surely hold up to my minute abuse.
BoomInIt, which gasket are you getting? The O-ringed one or the stock one?
Old Nov 25, 2006 | 12:28 AM
xonic's Avatar
Sheesh... That's some mod list. I hope you put down closer to 400whp than 300 w/ all the $$ you're spending.
Old Nov 25, 2006 | 12:13 PM
BoomInIt's Avatar
I think I will be going with the Cometic Headgasket, but I have both to choose from. The lsj crate engine should be arriving before christmas.
Old Nov 25, 2006 | 12:50 PM
BravoPuma6's Avatar
75LB injectors? event with those pistons and headwork 60's are more than enough as long as you stay at 7krpm. theres a balt in miami thats running that similar setup. after tuning was said and done he put down 309whp
Old Nov 25, 2006 | 12:51 PM
BravoPuma6's Avatar
by the way, dont go lower than a 2.7 pulley
Old Nov 25, 2006 | 01:36 PM
John's Avatar
hey ill buy the 2.9 pulley boys pulley from u
pm me if u want to sell it
Old Nov 25, 2006 | 02:15 PM
rollingboostedss's Avatar
what about your fuel system I know you are going to be running 75lb injectors, but will your fuel pump be able to hold up to that?
Old Nov 25, 2006 | 04:31 PM
Blown 4-banger's Avatar
Yeah, there might not be enought fuel pressure in the fuel rail to support injectors THAT big.
Old Nov 25, 2006 | 11:08 PM
  #36
CobaltPerformanceParts's Avatar
Fuel rail should support the injectors. However your going to have to run some kind of piggy back or resistor pack to run the larger injectors. You can find used resistor packs all over on the internet used for dirt cheap or you can make your own from some ballast resistors.
Old Nov 26, 2006 | 12:31 AM
  #37
BoomInIt's Avatar
I will be using the 60lb injectors due to the PCM and most likely be using Aeromotive 700 HP EFI Fuel Pump. There are a lot of other parts that are being used for the build that are not listed, but will be listed after completion. With pictures and video!
Old Nov 26, 2006 | 04:40 PM
  #38
crossed over's Avatar
why dont you just twincharge your car, i was told that with hahns kit coming out itll be putting out close to 350 whp when all is said and done, i also have been told that our cars will be able to hold that power being stock and itll just bolt right on, all we will need to do imo is upgrade the clutch and some axles and everything should be good.
Old Nov 26, 2006 | 07:03 PM
  #39
mattyfinch's Avatar
Originally Posted by BoomInIt
It will dump after the header with the cut out, the stocker will be modified slightly.
HAHAHAHAHA shortbus strikes again, first off, ur using 75 pound injectors why?
my 60/65 er's sit at 70% duty and i put down 294 whp... wow lol
stick with reality, ud have to hit 400 whp to even come close to maxing the 60's out, something u wont do lol
Also, maybe you should look at doing the valvetrain, ur maxing out the engine, u might as well let it rev and breathe like it wants..
as for exhaust, dont be a cheap ass noob, get a full 3 inch exhaust and grow up
Old Nov 26, 2006 | 07:05 PM
  #40
mattyfinch's Avatar
shortbus? i think so!
Old Nov 26, 2006 | 10:23 PM
  #41
xonic's Avatar
Opinionated much?? If he doesn't want to be buzzing around everywhere he goes the E-cutout is the best option. He'll be able to have the extra power from the better flow when he needs it and quiet stock exhaust everywhere else.
Old Nov 27, 2006 | 12:12 AM
  #42
BoomInIt's Avatar
I want to build my engine right that's why I'm starting with a crate engine and quality parts, not just bolt-ons. I bought the car for the reason of it being supercharged! I have plans on a twin screw conversion in the near future as well.
I was thinking 75's for the future 07 plans of the twinscrew. The stage 3 head has all Ferrea components!
DingDingDingDing! Right on the dot. Has nothing to do with being cheap considering 15k in upgrades. HAHA This is my daily driver.
Old Nov 27, 2006 | 12:49 AM
  #43
xonic's Avatar
$$$15k!! I'm still trying to convince myself to drop $2500 for mopar S3 (steel wheel) rather than dump it in the car payment. 15g's is definitely a lot to be putting in the car, especially when it's your DD.
Old Nov 27, 2006 | 02:21 AM
  #44
BrianSS's Avatar
15K!! I will trade for my dream Corvette C6
Old Nov 27, 2006 | 10:02 AM
  #45
BoomInIt's Avatar
But then I wouldn't be a cobalt...plus I can drive my bro's 500whp zo6.
Old Nov 27, 2006 | 06:16 PM
  #46
mattyfinch's Avatar
Nice theory, too bad our car relies on back pressure to properly operate the supercharger, therefore a cut out will in reality LOSE horse power, like in many applications, this isnt a 383 stroker engine, its a useless mod, that more then likely will hurt performance.
Old Nov 28, 2006 | 10:20 AM
  #47
Rogue's Avatar
Umm...no.
Back pressure is bad news on a supercharged engine because the pressure tries to stall the blower, making it work harder. And that extra effort saps power from the engine.
The cutout on my 465 horsepower Bonneville is easily good for about .2-.3 tenths when open. An engine is basically a big airpump the more you move through it the more power you make. Backpressure may make the car feel faster because it increases low end torque but at the expense of top end horsepower especially in a blown car. All race cars and fast strip cars have open exhausts.
Old Nov 28, 2006 | 12:07 PM
  #48
BoomInIt's Avatar
Originally Posted by Rogue
Umm...no.
Thanks for clearing things up. I know many people with e-cutouts and none lost any power! It keeps my everyday driveability.
Old Nov 28, 2006 | 01:15 PM
  #49
Sigforty's Avatar
Umm...no.
This is the most intelligent thing I have seen in this post yet.
