315ss #HondaHunting Lsj
Old 09-06-2017, 08:06 AM
mrbelvedere's Avatar
Originally Posted by 315SS
I'll take that bet .
2 weeks ago I trailered the car 12 hours to get tuned and do some dyno pulls. Unfortunately though only got 1 pull in and had to shut it down. Had enough blow by that the car started burning some oil.
Got it home tore the motor down, found the cause, purchased some custom JE pistons .02 over, had the block honed .02 over for the new pistons, just got everythint buttoned back up last night, assuming after some break in miles everything's mechanically sound I'll get it back on the dyno next week some time.
Planning on attending gridlife @ gingerman raceway first week of October if all goes as planned
the stock sleeves are only .060 thick you boring them .020 just made them a lot weaker I also see where you deleted that you made over 400hp on the first pull on a mustang dyno why did you delete that lol
Deleting the pcv return into the intake for a breather filter proved to be helpful in lowering my iat2 temps& with a good tune/tuner there aren't any ill effects
I know your full of **** the pcv has nothing to do with iat2 and running a breather has more ill effects on the engine producing hp then you think
Old 09-06-2017, 12:35 PM
cluelessk's Avatar
Ahahaha.
Old 09-06-2017, 02:44 PM
315SS's Avatar
The Custom JE pistons are .002 over & my block was honed by a local machine shop .002 over to match the new pistons. That's my fault, I typed it wrong.
lol I deleted that part bc there are too many trolls in forums. Everyone knows everything, (not directed at you mr.b) just in general, which is one reason why I typically don't partake in any discussion, advice seeking or anything.
Only reason I made this thread is bc it was brought to my attention another post had been made about my car & I thought I was finally finished and would have some results, mod list etc to post, but piston rings had other plans.
But anyways, yes on the 1st dyno pull to 9k Rpms the car did some smoking and after some diagnosing found that it was burning oil due to blow bye. Neither I or the tuner have published results from that one failed pull bc the result wasn't the best the car can do, even though it broke 400 on a mustang dyno on a decent day.
Old 09-06-2017, 03:06 PM
315SS's Avatar
I know your full of **** the pcv has nothing to do with iat2 and running a breather has more ill effects on the engine producing hp then you think[/QUOTE]
Hmm. You know that I'm full of **** eh??
When under load/boost, the crankcase vents out of the valve cover, through a hose, into the air intake, through the sc, through the intake manifold, into the head.
Stay with me here.
The air venting out of the valve cover is HOT air, said HOT air enters your COLD air intake. Being that air is HOT the iat isn't going to decrease, its going to increase. Obv. The boost is going to increase iat temps far more than anything else, but if I am able to eliminate any HOT air from entering the intake without sacrificing much/anything, I am going to being heat/hot air decreases sc efficientcy, and hp in short.
Old 09-06-2017, 04:08 PM
cluelessk's Avatar
You're pulling hot air from the engine bay. Doubt it's noticeably cooler. Plus when you're rolling iat's are very rarely that high. Worrying about it at idle is useless.
Old 09-06-2017, 04:19 PM
Sharkey's Avatar
if you have enough blowby as to where you have enough hot airflow out of the engine to affect your intake air temps you have bigger problems.
Old 09-06-2017, 10:36 PM
keiserX13's Avatar
and i thought i had a long mod list
keiserX13's Avatar
any pics of the build?
Old 09-07-2017, 01:07 AM
It doesnt exist
Old 09-07-2017, 02:27 AM
315SS's Avatar
I never said that the hot pcv air was affecting my iat, I said is one of the reasons I chose to go with a pcv breather rather than a catch can, no biggie.
Essentially every decision I've made wether it be parts purchased or something dumb like a pcv delete I've gotta defend every move I've made to the trolls.
Mr. b would have done everything different than me 🤦🏻*♂️, & has criticism for everything, one can only assume he hates the playa & loves the game🤷🏻*♂️
Old 09-07-2017, 02:29 AM
  #36
315SS's Avatar
Old 09-07-2017, 02:31 AM
  #37
315SS's Avatar
Old 09-07-2017, 02:35 AM
  #38
315SS's Avatar
Ssr subframe connectors
Old 09-07-2017, 04:52 AM
  #39
315SS's Avatar
I'm clearly not pulling hot air from their engine bay? 😉
Old 09-07-2017, 11:14 AM
  #40
Henry3959's Avatar
And you all wonder why the SS.net traffic has slowed to a crawl. To each their own!
315SS.... do what makes you happy.
Old 09-07-2017, 11:33 AM
  #41
It all depends how you take it really, some comments aren't needed I'll agree on that but mr.b was only giving advise, with all the knowledge he has.
In the end the car belongs to 315ss and he can do as he pleases with it.
Old 09-07-2017, 11:35 AM
  #42
user 72239's Avatar
traffic hasnt slowed cause mrb is a dick. hes always been a dick.
traffic has slowed because of Facebook. Its easier to post there, than come on here. plus this platform has been dead for 7 years.
07MetallicSC (09-07-2017)
Old 09-07-2017, 11:37 AM
  #43
royce777's Avatar
what did you coat the car with on the underside and interior?
Old 09-07-2017, 12:03 PM
  #44
Henry3959's Avatar
I'm not calling out any specific members... the list is too long. Even I have been called a Dick
Old 09-07-2017, 12:52 PM
  #45
07SC_79BanT/A's Avatar
Kind of looks like Bedliner or some anticorrosive/rust spray stuff Streetspeed717 put under his Duramax on YouTube.
Old 09-07-2017, 01:04 PM
  #46
I need to do that lol I enjoy watching his videos
Old 09-07-2017, 01:30 PM
  #47
jdbaugh1's Avatar
I think the Streetspeed717 guy is annoying. Also that subaruwrxfan guy.
cluelessk (09-07-2017)
Old 09-07-2017, 01:46 PM
  #48
zeeky420's Avatar
I do agree some of the guys come off with dick comments but it's just like text things can be taken wrong on how somebody reads it but this is a nice little build here some things I would do some I wouldn't but it looks like thi ngs are coming together well
Old 09-07-2017, 02:04 PM
  #49
Henry3959's Avatar
I just want the money being spent!
Old 09-07-2017, 02:17 PM
  #50
Not to mention this site used to be even worse when it was busy, this is mild.
