400 HP build?
400 HP build?
ok i was just sitting here thinking and figured id ask what are ALL the mods that someone would need to build a 400HP SS/SC? without going turbo or to a diffrent supercharger that is. when i warranty is up (not for a long time) i fully intend on achieving 400 or more HP and dont know what all mods/supporting mods i would need...
can anyone help me?
can anyone help me?
not possible
or realistic unless ur gonna build a brand new motor but then why not fork out for a new s/c or turbo? ur not getting 400 with stock internals period
should have posted that but trust me i know stock internals wouldnt cut it thats why i said ALL mods/supporting mods i would need
you would proably need every thing in the motor rebuilt and ported and all that jazz... then you would either need n2o or like a 2.3 inch pulley and over spin the crap outta the s.c... and you are gonna need some serious cooling mods... but i could be worng.. i think its easier to just go turbo or change the supercharger
well if ur gonna build an engine ur best bet is to go 8.8 to 1 compression and port and polish ur supercharger/head and then get a ZEX™ EFI Perimeter Plate Nitrous System and squeeze every drip outta ur car and hope u dont blow nothing up paul walker lol...just not worth it to find any other route then the right one bro but just my 2 cents
well I don't know the cost but u'd want a sleeved block bc our motors use 10:1 compression pistons which have almost no skirting and will scar a cylinder walls.....so forged pistons, sleeved block, arp studs, steel head gasket, built head, exhaust components, and a s/c swap; turbo; or ported and polished with meth. injection...that would be a good start IMO......and if you fall short traction mods to put the power to the pavement.....and with 400hp..u'd need new axles and of course a clutch.....you could always use nitrous...if your bottom end and head is built and spray like a mother f**ker
A fully and correctly built LSJ should net you well over 300. We are talking about balancing and blue printing the motor, and completely re-doing the internals, maybe even boring it out a bit as well.
Nitrous will get you there faster with a little less work, but as you can see in my sig...Me no big fan o nitrous.
thats for the most part true. The crank is the only stock internal that will handle that kind of power. its rated to 500 hp but its max rpm before it disinagrates is 8000 rpms. somone on here went to 8100 rpms and it disinagrated
My crank is still holding and I went to 8300 rpm lots. 400hp on pump gas isn't possible in my opinion.
GM ecotec build guide doesnt mention anything about head work till you get over the 500hp mark.
currently i have ferrera valves and springs w/ titanium retainers, comp cams stage 1 cams, wiesco forged 8.9:1 pistons, egale forged rods, ARP head studs, ACL rod bearings, Honed cylinders, 3 angle valve job on the head, and a GM ecotec build guide engine rated to handle 500hp. (need to change out the crank if i want to go over that)
Besides, didn't you say you were going with Lower Compression pistons for your twinscrew?
Without Nitrous or Turbo, you are not going to do it with the stock M62.
I think thats a challenge! Not for me though, for someone with money
