42lb limit
Matt said my 42s were maxed out when he tuned my car. I'm on a Stage II pulley with an intake, custom tune, 1 step colder plugs and full exhaust. It made 262whp on a Mustang Dyno...
Rent me! per hour
not exactly.
base pressure of 58. do some calcs based upon this number. we. the stock returnless people. are cramming more fuel into the injector as it is.
the 42's basically work as 50's.
so your sayin it'd just be better to drop a pulley size with a tune on 42's to get the best effect?...2.9 or 2.8?
just asking cuz with a 3.0 pulley i thought they were borderline going static...an a 2.9 through them static already
There are too many variables to say how much hp you'll get out of the injectors, but one thing is certain, you'll get more out of a turbo than you will out of the s/c, because as said above, the s/c takes hp to spin.
i.e. 300 crank
300 hp - 40 to spin the blower = 260 for the drive drain - 15% drag loss ~ 221 at the wheels.
300 hp - 0 for the turbo - 15% drag ~ 255 at the wheels.
Blower losses will vary from person to person, but the general rule of thumb is that the higher the boost, the more energy required. If you drop the pulley down, but free up the airflow, you can get a cooler charge of air and lower the overall boost while increasing power and minimizing the blower loss.
I believe under ideal conditions, 42lb injectors (actually flowing at 42lb), are good for just over 300 crank hp. As also said, though, the fuel pressure of the ss/sc makes them flow more than 42lb/hr.
So many variables.
i.e. 300 crank
So many variables.
My numbers are rough estimates, but you get the idea. I believe I read somewhere that on the ss/sc stock, the blower consumes 35 hp to make the 12 psi. So take your average whp dyno of around 200, add ~30 for drivetrain loss, and ~ 35 more for the blower, and your stock LSJ is doing roughly the same amount of work (hp) as the LNF. Except due to mechanical differences, you're getting less power to the tire, and consuming more fuel to do so.
Is it safe to say if you can run 15 psi on the Heaton it's safe to run ~15psi on a Garrett T3 T4?I know turbo size don't create the same hp per lbs as some others..
Turbos compress air different than an s/c, and I don't know enough about them to give a good answer there. Sorry.
What's the number before the 300hp? You know the bare bones engine before adding the supercharger or turbo that'll really surprise you.
Those numers weren't supposed to represent any specific engine, and there's no real point in knowing that number anyway, as engines built for boost will generally make less n/a power than one not built for boost.
