42lbers/60lbers?
Old Aug 8, 2007 | 02:10 PM
williamhvx1's Avatar
Originally Posted by Jmc007
It depends mainly of how much boost you run, hence the differential pressure going through the injectors. For 16+ PSI in the manifold, 42# can flow a bit not enough for the last RPM's, specially if you go past 6500 RPM.
AND ACTUALLY i got a stage 2 and really honest after 6500 the car dont pull that hard so then a 42 is ok just be a intelligent drive
Old Aug 8, 2007 | 02:16 PM
blown06's Avatar
If you are going to be maxing the rpms at 7k do not do 42's and 2.8 do the 60's. I am telling from expecience and a profession tune done at between 6800-7000 42's on a 2.9 are at 100% duty cycle. Either do at set of 60's or 50's
Old Aug 8, 2007 | 02:19 PM
Area47's Avatar
Rent me! per hour
my 42's with the 2.8 are at 85% at 7k rpms
Old Aug 8, 2007 | 02:28 PM
GET SOME GOOD 42 double match flow!!!!!! like pte 42 lbs
Old Aug 8, 2007 | 02:39 PM
Edubs's Avatar
X2...
Old Aug 8, 2007 | 06:11 PM
Sanat's Avatar
Ight I just need to find someone who will tune my car good!
