I was just wondering if you guys that are running the 60lb injectors and if you are actually using this as a daily driver and what MPG are your getting...i was j/w..
When goin with the 60's you are going to need a tune to adjust. With the right tune, I don't see you losing all kinds of fuel mileage. If anything,depending on your setup, you may gain some.
When I got my 60lb. injectors and tune I saw an increase in my MPG. Before the injectors and tune I saw about 23-24, after the injectors and tune I see 25-26 mpg.
Here is a log of my gas millage with the 60 lb/hr injectors.
30-35% engine load is cruising speeds. Anything less is coasting, anything more is accelerating
