?? about the mounts and vibes
Old Oct 18, 2007 | 07:00 PM
D4u2s0t's Avatar
for the guys that get bad vibes with their aftermarket mounts, what rpm does your car idle at?
Old Oct 18, 2007 | 07:35 PM
OrngBalt's Avatar
aight we get it dick.... you dont have any vibes...
but seriously... i get vibes under 1000rpm
my idle is usually around 750
Old Oct 18, 2007 | 07:49 PM
D4u2s0t's Avatar
nah dude i'm asking a serious question here! people complain about how bad it is, and the vibes only seem to happen for people at idle and take off, so i'm curious
Old Oct 18, 2007 | 08:26 PM
Johnboy12358's Avatar
I get vibes when I am idling around 750-800 rpms, all I have is the damper
Old Oct 18, 2007 | 08:35 PM
KillerBee's Avatar
anything higher then idel mine go away mine are barely there any more i put about 5000 miles on them and there are almost gone but still no wheel hop
Old Oct 18, 2007 | 09:45 PM
Silv3r's Avatar
i get vibes under 800rpm, and when im backing up a lil bit. I also noticed the damper translates a lot of engine noise through the chassis, and its very loud inside the car.
Old Oct 18, 2007 | 09:50 PM
XM15's Avatar
It vibrates only at idle. As soon as I hit the gas, putting the RPMs above 1K, they go away. I have also noticed that after a thousand miles or so most of the vibrations have gone away. Either that or I'm just used to them now. Regardless, I kind of like the vibes.
Old Oct 18, 2007 | 09:59 PM
D4u2s0t's Avatar
this is confirming what i thought, thanks guys. i most likely don't feel any vibes because my car idles at 1000, and everyone seems to feel them only below that.
Old Oct 18, 2007 | 10:32 PM
IMADreamer's Avatar
That makes sense. I just put my trans mounts on today and it only vibes at idle. Once I'm off the clutch moving forward it's just like it was before the mounts. The car hooks up so much better though I'd gladly deal with the vibes.
Old Oct 18, 2007 | 10:35 PM
UmeNNis's Avatar
my question is why your car idles at 1k when from the factory its set to between 750 and 850 ???
D4u2s0t's Avatar
no idea. maybe the tune i guess. it's normally between 900 and 1000 at idle.
Old Oct 18, 2007 | 11:48 PM
HunterKiller89's Avatar
mine shakes hardest at 1krpm when under throttle. if im pulling into a parking space on a slope for example, and am using the gas but am still at 1kRPM, those are my worst vibes....i love it
Old Oct 18, 2007 | 11:58 PM
KillerBee's Avatar
turn on the ac and watch your girl have an orgasim
Old Oct 19, 2007 | 12:03 AM
D4u2s0t's Avatar
the ac doesn't vibrate the car either
Old Oct 19, 2007 | 12:05 AM
KillerBee's Avatar
oh but if you have all three solid mounts and turn the ac on at a stand still your like vibrating right off your seat
Old Oct 19, 2007 | 12:07 AM
D4u2s0t's Avatar
i have 2 mounts and the ingalls set to the stiffest it goes. i'm sure the solid engine mount makes more, but i literally feel no vibes. i don't get why my car is like that when everyone else's shakes.
Old Oct 19, 2007 | 12:14 AM
KillerBee's Avatar
well mine aint that bad anymore not as bad as it was when i put them first in but maybe your bolts came out
Old Oct 19, 2007 | 12:15 AM
D4u2s0t's Avatar
no lie i checked them the other day!
Old Oct 19, 2007 | 12:17 AM
KillerBee's Avatar
where did you get yours did you drill holes in yours
Old Oct 19, 2007 | 12:28 AM
lsjwannabe's Avatar
when i take off only
Old Oct 19, 2007 | 10:14 AM
D4u2s0t's Avatar
got them from ttr. no holes. i did shave the lip off a little bit to get them in better, but still they're in there tight as hell. jumping up and down on it i still couldn't get it in, had to bang it in with a hammer.
i just tripple checked, everything is super tight. o well, guess i shouldn't be questioning it
Old Oct 19, 2007 | 10:34 AM
Hurt-ya's Avatar
i got the torque dampner, and both tranny mounts
I idle lower cus of my spark plugs.. like 750 950
I love the vibration of the car... the shifts are smoother and stronger
Old Oct 19, 2007 | 10:38 AM
KillerBee's Avatar
damn i squeezed my in with my bare hands but i took out the center metal thing when i put them in then i put in my metal tube
Old Oct 19, 2007 | 10:43 AM
Formula96's Avatar
vibration on take off only, or if i have the ac on.
at my 750-800 idle i dont notice it.
It was very bad at first but over time it got better.
Old Oct 19, 2007 | 10:47 AM
SSKevinSC's Avatar
Mine idles at about 850, I installed my Prothane mounts about 1000 miles ago and the vibs are only bad at take off now. They are not bad at an idle unless it is first thing in the morning.
