aem wideband.
Old Nov 24, 2010 | 06:41 PM
T CUPP's Avatar
aem wideband.
will a aem wideband hook right up to my stock downpipe?
Old Nov 24, 2010 | 06:42 PM
Turbalt2010's Avatar
i dont think it will because you need an extra bung for the wideband.
you could probably have a bung welded in? im not 100 percent sure. just trying to help
Old Nov 24, 2010 | 06:54 PM
chevysssc's Avatar
you need to weld in the bung. its like that on every dp unless you order an aftermarket dp with an extra bung welded in.
Old Nov 24, 2010 | 07:53 PM
T CUPP's Avatar
how much does that usually run to get them welded in? and is there any specific place it needs to be welded in on the dp
Old Nov 24, 2010 | 07:56 PM
troyss's Avatar
Bout 20-30 dollars... Put it in front of your stock senser.. Towards the header, about an 3inchs away but not sure the exact length
Old Nov 24, 2010 | 08:04 PM
iboost's Avatar
Anyone ever try one of these...
AEM No-Weld O2 Sensor Mount 1.75-2 inch exhaust
all you really have to do I guess is drill a hole and put this over the hole...no welding needed for a bung...
Old Nov 24, 2010 | 10:12 PM
T CUPP's Avatar
why put it before the sensor?
Old Nov 24, 2010 | 10:33 PM
Bluelightning's Avatar
Got Bewst?
Mount the sensor before the cat. It will be more accurate. I had to take out my downpipe to weld in the bung. Not much room up there
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
nathan112i
Sep 30, 2015 07:12 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
