AEM wideband problem
i just installed my uego AEM wideband and everything went smooth. tapped it into the wipers fuse and grounded good. turned the key to the on position, let the sensor warm up (the gauge started at 14.8 then slowly but picked up speed till - - - showed. turned on the car and the gauge worked. went for a test run down the highway, but the gauge went crazy. it never was in the green(never below 13.1), always yellow and red showed(always above 13.1 or got the - - -) What could be the problem? i tried following the instructions word for word. i know my car isnt running what it says so what could be wrong?
thanks
thanks
It is always going to sweep back and forth unless you are under WOT, then it will hit approx 10.0-11.5 (depending on you tune). Don't worry man that is what is it suppose to do!
i hope so when i took it out i didnt know what to think. this is my first a/f ratio gauge. i knew it swepped back and forth but mine was going nuts. ill have to try a WOT pull tomorrow never got to today.
thanks for the quick reply!
also did everyone keep their settings to P0 or did you change it?
No problem man, but yeh at WOT it will level right out. I haven't played with mine lately but I think you have to change that in order get "shift lights" Play around with it.... Can't really wreck it
n20saturn
09-30-2015 12:26 AM
