AeroForce Scan Gauge
Old Sep 17, 2005 | 08:30 PM
DanM's Avatar
Hey guys... AeroForce Tech now has a version of their scan gauge for the Cobalt SS. I got one a couple days ago, and am REALLY happy with it. It can scan a whole whack of engine parameters including simple things like engine RPM, coolant temp, vehicle speed, etc., but also more useful things like fuel trims, ignition timing, MAF rate, and even knock retard!!! They were actually able to get two more extremely useful parameters for the Cobalt SS too, namely the SC inlet pressure, and the temperature of the air charge AFTER the supercharger!
After driving with it for a couple days - I'm actually very surprised at how low the post-SC air temps are. At idle, they only seem to creep up to 50-70degF above the pre-SC air temp, and when you're moving (ie decent flow rate), the temps generally stay only 30degF above the pre-SC temp! Looks like the SC isn't heating the charge much at all!!
Here's some pics (excuse the quality, my cam was having a hard time focusing on it. i couldn't get any daytime pics cause the face of the gauge is so reflective that it kept throwing off my cam!)
My only real complaint with the gauge is that you have to find an ignition wire somewhere to tap into. Not a huge deal, but it does take away some of the "plug and play" appeal of it. All in all, all the parameters + the ability to scan for codes.... this thing is a steal for $220. Now I just need AutoMeter to make a pod for me to put it in.
Old Sep 17, 2005 | 08:32 PM
rallyracer's Avatar
sweet
Old Sep 17, 2005 | 09:21 PM
selfinfliction's Avatar
that is really good considerign the operating temps of the blower i think eaton says it's 180...50-75 degrees lower is huge
Old Sep 17, 2005 | 09:25 PM
DanM's Avatar
Exactly. And in fact, it's COOLEST at WOT. The temps only get higher when you're idling (ie air flow rate is low), so there's not much air to absorb the heat. As soon as you start moving/increasing airflow, the temps start to drop quickly.
Old Sep 17, 2005 | 09:54 PM
MarcS's Avatar
The Stig
Wow, this is a real nice and useful gauge. I want one
Old Sep 18, 2005 | 12:39 AM
silverSS's Avatar
that thing is cool, where did you buy it at?
Old Sep 18, 2005 | 12:40 AM
DanM's Avatar
www.aeroforcetech.com
Old Sep 18, 2005 | 12:53 PM
silverSS's Avatar
im sure autometer has a pod for it, but where are you going to put it?
Old Sep 18, 2005 | 12:57 PM
97cavie24ls's Avatar
ive got 1 on my s/c'd cav , and love it
im also talking with gravanatuning about having a g/p for them
so you guys should drop him a line to let him know your interested also
sales@gravanatuning.com
Old Sep 18, 2005 | 12:58 PM
DanM's Avatar
That's the problem. AutoMeter doesn't have any pods designed for the Cobalt yet.
They have some generic A-pillar pods, but the fit will suck if it's not made for the car. I'm waiting for either a cluster bezel that can fit two of them, or preferably a center dash pod, so long as the fit & finish is good.
Old Sep 18, 2005 | 03:41 PM
clownhair's Avatar
I need to pick one of these up soon. What do you need an rpm input for?
Old Sep 18, 2005 | 04:19 PM
DanM's Avatar
You don't. I mean an ingnition POWER feed, as in a wire that's 0V in off, 12V in RUN. The gauge needs it to know when to turn on.
Old Sep 18, 2005 | 05:04 PM
clownhair's Avatar
oh, thats no biggie then.
Old Sep 18, 2005 | 11:27 PM
06black's Avatar
how much are they and were the crap can i get this amazeing thing!
Old Sep 19, 2005 | 12:34 AM
rallyracer's Avatar
LEARN TO READ ^^^
Old Sep 19, 2005 | 02:48 AM
read my post , bug jim at gravana tuning
the more people that ask him the sooner we can convince him to set up a GP for them
Old Sep 19, 2005 | 06:41 AM
SuperSS-Boss's Avatar
SWEEEEEEEEEEEEEEEEET!!!! I love it... It will go well with my AutoMeter Cobalt D-Pic and Cobalt A/F Guages, when i finally get my CAR!!!! Nice find...
Old Sep 20, 2005 | 11:15 PM
silverSS's Avatar
http://videos.streetfire.net/Player....4-765CBD202281
here is a video of the gauge in action on a redline, but he never flipped through the SC inlet option, is it the same gauge?
How did you power it? does it just hook up through the ignition and run from your battery or what?
Old Sep 20, 2005 | 11:48 PM
MarcS's Avatar
The Stig
I'm more interested in the OBD2 version, will it also work on the 05-06 Cobalts?
Heres one that I found:
https://www.flp2win.com/store/produc...roducts_id=385
Old Sep 20, 2005 | 11:54 PM
zinner's Avatar
Moderator Alumni
I agree we need a pod to mount it with. I am happy to see they got all the variables working.
Old Sep 21, 2005 | 12:10 AM
fljohnboy's Avatar
I had one of these in my GTP and it only plugged into the diagnostic port. Aeroforctech did a group buy for the Pontiac guys so if enough people were interested they will make a deal.
Old Sep 21, 2005 | 06:24 AM
DanM's Avatar
The SC inlet pressure is a new variable they just got working. It will be on all the RL/SS gauges. As to power, you need to wire it to a 12V ignition feed somewhere. There are several of them that you can use all underneath the IP on the driver side. I found the best one to use was the 12V ignition feed for the EPS controller. You could also wire it around to the electrical center behind the passenger side kick panel. Plenty of options there.
They're all OBDII. That's the same one as on their website... all the same product. If it weren't OBDII, it wouldn't work on our cars at all.
Old Sep 21, 2005 | 02:05 PM
like i said before , email gravana tuning about them
ive been talking with jim about them for a while now , and if you guys are wanting them this will be 1 of the best times to do so
but expect a dealy in him getting back to you , he is working on the SEMA cars , so give him a little time
Old Sep 29, 2005 | 01:29 AM
zinner's Avatar
Moderator Alumni
I just installed an Aeroforce gauge too. I opted to put it in place of the stock boost gauge for now. It was a <30 minute install. I had a switched 12 volt already run in for my piggy back from the ECU so I tapped into that.
I took it out for a spin tonight and I will get some pictures of the install tomorrow when it's light out.
So far very cool. I have boost in PSI and Intake Air Temp 2 (post supercharger) on display right now.
Old Sep 29, 2005 | 12:22 PM
zinner's Avatar
Moderator Alumni
Here is a picture of the gauge installed.
Here is a little video of the gauge in action.
http://www.cobaltss.org/albums/aerof...nterceptor.avi
