Air/Fuel Ratio gauge wires
which wires are the sending wires that a afr gauge needs to be tapped into, and which is a better sensor to use, the front or the rear???
i dont remember the wires but in the engine bay by the fuse bloc there is a loom of wires...... thats were you can tap in for signal (i think its a solid purple wire or purple and white) dont quote me. power would go to something that only turns on when key is on (obviously) black would be ground and anywhere inside the car can be ground
