Air Fuel Ratio Question
Hey,
I installed a AEM UEGO wideband today, and did a few 2nd and 3rd gear pulls to see what my ARF wad. As far as mods go, I have GM stage 2, injen intake, Vibrsnt hesder/downpipe, and Ark DTS cat back exhaust. I was expecting to be running really rich with the stage 2 tune, but my air fuel ratio was in the mid 12's which in lean. Does anybidy know what could be causing this??? Could there be a problem with the gauge, or am I actually running lean.
Thanks in advance,
Chris
Thanks in advance,
Chris
I just have the stock GM stage 2 pulley. I just dont understand how I could be running lean with my mods. Also GM installed the stage 2 kit, and I am asuming that they did the reflash correct because the car redlined at 7200 after they installed the kit. That is why I am leaning toward it being a problem with the gauge or sensor. The stage 2 has been on the car for about a year now, andif I was running this lean the whole time im sure that I would have had problems bu now. I just purchased a 2.9 inch pulley but, am def not going to be putting that on untill I get this straightened around.
RL should be just 7K.
I figured that would be obvious. Even with a 2.9 it will have really high IDC's but it was pertaining to how the GM tune adjusts.
Last edited by Perfect.disguise; Feb 21, 2009 at 07:22 PM. Reason: Automerged Doublepost
where is the sensor positioned at? is it after the cat or before? do you have a cat?
i saw the vibrant h/d now. lol, so where is the sensor located on the downpipe?
Last edited by BLAZIN07SS; Feb 21, 2009 at 08:15 PM. Reason: Automerged Doublepost
What position is the sensor? It needs to be at 6'oclock for the best readings...it may be a faulty o2 sensor as well, or maybe you have a huge leak somewhere? Check your connections along the intake.
To the OP: It may be possible that it's reading off, but the only way to know for sure is to take it to a dyno with a sniffer and do a pull. Maybe if you're friends with a shop you can talk them into letting you do one pull for $25 or something just to see. I think the O2 sensor on my Innovate is bad - keeps saying I'm cruising around 14.3 instead of the 14.7 it's commanding, but the only way to know for sure is take it to a shop or put someone else's WB in, unfortunately.
I was told that 6'0clock was the best reasoing, might be wrong but condeentation seems to collect at the highest point.
I had the bung welded in in the 3:00 position, so I know that the position is not the problem. Does anybody know if there is a way to test the bosch sensor to see if it is bad. I am hoping that it is a problem with the sensor, and I am not actually running lean on a stage to tune and stage 2 pulley.
OP: Unfortunately there's no way to test the sensor by itself that I know of. You would need to swap in a new sensor and see if it's reading the same, or take it to a dyno.
OrangeCoba
Sep 25, 2015 06:06 PM
