The air/fuel ratio of the stock SS/SC
Old May 6, 2006 | 02:29 AM
NJHK's Avatar
Question The air/fuel ratio of the stock SS/SC
I'm just curious as far as what you guys are running as far as a/f ratio at wide open throttle, idle and just basic cruising.
FYI: I'm looking for actual numbering range from widebands...thanks.
Old May 6, 2006 | 07:44 AM
Jmc007's Avatar
Air fuel ratio on a stock Cobalt SS/SC is too rich and range from 11:1 to 10.6:1 (at least the 2005 Cobalts SS/SC). 2006 tends to be slighlty leaner for the last RPM's.
Old May 6, 2006 | 08:41 AM
PauL500x's Avatar
Is this basically compression ratio? And what is running rich or lean?
Old May 6, 2006 | 04:31 PM
NJHK's Avatar
We are talking about air fuel ratio which is read through the exhaust with an Wideband O2 Sensor. Compression ratio has to do with the volume of your combustion chamber when the pistons are at the bottom of it's stroke.
Running rich is when there is too much fuel being sprayed into the motor. Running lean means there isn't enough fuel being sprayed into the motor. Both in extremes can hurt your performance or damage your motor...of course there are degrees of both...you can run slightly rich and be fine and run slightly lean and be ok but on boosted applications, it's best to run rich than lean. Leaning out leads to detonation.
Old May 6, 2006 | 04:33 PM
NJHK's Avatar
And this is with what size injectors? 36#?
Do you happen to know what the base fuel pressure stock?
Old May 6, 2006 | 05:45 PM
PauL500x's Avatar
Would getting your car tuned fix this? Any suggestions...
Old May 6, 2006 | 08:33 PM
Jmc007's Avatar
Stock injectors are 34 lbs/hr (rated at 43,5 PSI) but the fuel rail pressure is set at roughly 60 PSI.
Old May 6, 2006 | 11:56 PM
NJHK's Avatar
Thank you very much.
Old May 6, 2006 | 11:59 PM
NJHK's Avatar
Yes. Not exactly sure how you would with the SS/SC though...
Old May 7, 2006 | 12:04 AM
PauL500x's Avatar
I saw in these forums that you can tune the SS coupe but nothing about the s/c Cobalt. Why cant they do it with the s/c Cobalt?
Old May 7, 2006 | 12:13 AM
NJHK's Avatar
I think you're referring to the "reflash" that some of them are getting.
I think the reason that GM has their motors running so rich is to prevent detonation...I mean, stock they are doing about 10-11 PSI max.
You could always get some type of standalone unit to take full control but that's the only thing I can think of.
Old May 7, 2006 | 02:34 PM
cgss's Avatar
whats an ideal air/fuel ratio?
Old May 7, 2006 | 05:35 PM
NJHK's Avatar
In what situation?
Old May 7, 2006 | 05:57 PM
EndZz's Avatar
I did mine yesturday idles at 14.4 crusing at 14.0 pretty solid at crusing. Then after 3800rpm the A/F ratio starts to drop from 14.0 to 13.1 it stays that way till 5200rpm then it drops to 12.4 then it drops again at 5800rpm from 12.4 to 12.0 then again at 6200rpm down to 11.1 I'll draw it out.
14.4----2300-3600 rpm
13.9----3600-3900 rpm
13.9 decends to 13.1----3900-4500rpm
13.1----4500-5200rpm
12.4----5200-5800rpm
12.0----5800-6200rpm
12.0 decends to 11.1----6200-6400
11.1----6400-6500rpm
That as accurat as I could write it without showing you the sheet sorry. BTW This is all with a CAI installed on the car stock the A/F ratios were 0.1-0.2 lower. Not much of a difference
Old May 7, 2006 | 11:28 PM
NJHK's Avatar
Thank you very much
Looks like the computer knows exactly what it's doing to keep you guys from detonating
Old May 7, 2006 | 11:33 PM
PauL500x's Avatar
What a/f ratio would you guys reccomend. At my peak RPMs, I want to run very slightly rich. Check my sig to see what mods I want too. Also, can you tell me of a 2.7 in. pulley will be safe or should I stick to the 2.9?
Old May 7, 2006 | 11:40 PM
italstalnprd86's Avatar
mmine is 14.7:1 at idle, is that bad? I have a 3 inch pully and an intake, how can i fix it?
Old May 8, 2006 | 12:00 AM
NJHK's Avatar
First, I would buy a wideband to know what a/f ratio you're running at NOW.
Old May 8, 2006 | 12:03 AM
NJHK's Avatar
14.7:1 is fine for idle. Frankly, as long as you're not in one extreme of an a/f ratio (example: you're idling at 10s or idling at 18s), you should be fine.
zinner's Avatar
Moderator Alumni
I am running at almost exactly 14.7 at cruise and I am at about 12.5-12.8 at WOT at the redline.
These readings from a WB 02 pre cat and a CAI/Exhaust and 3 inch pulley.
Old May 8, 2006 | 02:54 AM
EndZz's Avatar
All of those A/F ratios I gave you are at WOT. By Cruise I meant slight acceleration 15% throttle but if you are on flat ground maintaing speed you will be at 14.7 so don't try to "FIX" it besides (it's good for the environment) you could use less fuel going to 15.0 at cruise. But for more power you can make the A/F ratio begin to drop at 3200-3300rpm instead of 3900rpms you will see an increase in TQ sooner rather than waiting for 4200rpms to get most of your TQ.
Old May 8, 2006 | 03:01 AM
NJHK's Avatar
Agreed.
Old May 8, 2006 | 03:37 AM
EndZz's Avatar
Those of you who are saying you are at 14.7 and asking if it's bad take a look at this.
BTW try to keep the stock A/F ratios when modifying things and change MAP tables if you are using HPT
9.0:1 BLACK SMOKE (NO POWER)
11.5:1 RICH BEST TORQUE @ WOT
12.2:1 SAFE BEST POWER @ WOT
13.3:1 LEAN BEST TORQUE @ WOT
14.6:1 STOCHIMETRIC AFR ( CHEMICALLY CORRECT )
15.5:1 LEAN CRUISE
16.5:1 BEST FUEL ECONOMY (EXCEPT FOR HONDA MOTOR COMPANY)
18.0:1 CARBURETED LEAN LIMIT (EXCEPT FOR HONDA MOTOR COMPANY)
22.0:1 EFI LEAN LIMIT
Old May 8, 2006 | 03:40 AM
NJHK's Avatar
If you hit 9.0, your car must be completely off balanced and you are gonna flood your motor in no time lol
Bye Bye O2 Sensor lol
Old May 8, 2006 | 01:28 PM
memphisr24's Avatar
Why are you guys with 3 inch pulleys, cai's, and exhausts getting 12.5-12.8's when I'm getting 13.5-13.7 WOT!?!?!? I have the same mods.
