Air Intake Temps
Old Aug 5, 2010 | 01:42 PM
Superman_Davin's Avatar
Air Intake Temps
Just got my Interceptor gauges installed. Drove around to get the car warmed up.
89* outside, ~100*F IAT1, ~170*F IAT2.
See a problem?
Old Aug 5, 2010 | 02:18 PM
Bluelightning's Avatar
Got Bewst?
89* outside, ~100*F AIT1, ~170*F AIT2.
See a problem?
Check you're intercooler pump. Sounds like its not working
Old Aug 5, 2010 | 02:40 PM
395 plus's Avatar
Do you mean IAT (intake air temp) Even that your IAT1 is high are you using the stock intake?? My intake air temp is in within 1 or 2 degrees of ambient air temp. My IAT2 is within 15 to 25 degrees of IAT.
Old Aug 5, 2010 | 04:23 PM
I thought it looked weird. Thanks. I have the RAW 3" CAI... with the occasional lean code.
I'll have to look into the pump. Hopefully that fixes it. If not, I have parts on order.
Old Aug 5, 2010 | 04:43 PM
skatin_boarding's Avatar
try smacking it with a hammer.
Old Aug 5, 2010 | 05:31 PM
Karlen89's Avatar
Check the coolant level. Check pump. Order new pump. hammer doesnt make it work forever.
Old Aug 5, 2010 | 06:48 PM
paddock's Avatar
I just intstalled the opt B with the dual pass and I'm lucky to see a 40F swing in temps between IAT1 and IAT2. I know my pump is working. Is there something wrong still???
Old Aug 6, 2010 | 01:09 AM
Karlen89's Avatar
Ya, if your temps are that high, you might have the hoses routed incorrectly.
Old Aug 6, 2010 | 10:42 PM
paddock's Avatar
Routing is good. Laminovas were swapped.
Old Aug 7, 2010 | 12:03 AM
Got Bewst?
That'll do it
Old Aug 7, 2010 | 04:12 PM
paddock's Avatar
That'll do what? The install instructions told me that they needed to be moved around....
Moved 'em according to the instructions.
Old Aug 23, 2010 | 06:49 PM
I finished installing ZZPs Stage 3 Heat exchanger, Dual pass endplate, and option b. Used Dex-col, distilled water (50/50), and Water Wetter. Drove around this morning and i'm still seeing about 60 degree differance....
I'm pretty sure the pump is bad, just not entirely dead yet. Any thoughts?
Old Aug 23, 2010 | 09:18 PM
mrbelvedere's Avatar
change the pump and quit whining about it
Old Aug 23, 2010 | 09:26 PM
Got Bewst?
I finished installing ZZPs Stage 3 Heat exchanger, Dual pass endplate, and option b. Used Dex-col, dilstilled water (50/50), and Water Wetter. Drove around this morning and i'm still seeing about 60 degree differance....
Outside temps and humidity play a big part too. When i installed mine i didn't notice a huge difference in temps. Bit cooler on the highway. The biggest thing was when i had my foot into it the temps would climb a bit slower and recover super fast
no_ss
Oct 18, 2015 11:58 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
