AIS fender mount with windshield washer tank
So when I got my kit it came with the truck mount kit instructions, so I was just curious about tapping into the washer fluid tank...
Do I just drill a hole somewhere, run the hose to the bottom of the tube and seal it up with some kind of methanol friendly sealant? Also, I have read the pump needs to be mounted below the tank, is that true, and if so where do you mount the tank? Thx Mike |
apperently its better for the pump to be higher but i put it above and it works fine...as for the tapping of the tank...i drilled a hole then tapped it then threaded the piece in there...just take the piece into a ACE and they will give u the right size drill and tap...its realy easy just go slow..
Here's the complete guide of my installation for your kit!
http://www.ticpu.net/~jerome/pics/?path=./meth I did also get the trunk mount guide, but after some help from AIS, I had this kit installed in one afternoon. |
