AIS fender mount with windshield washer tank
So when I got my kit it came with the truck mount kit instructions, so I was just curious about tapping into the washer fluid tank...
Do I just drill a hole somewhere, run the hose to the bottom of the tube and seal it up with some kind of methanol friendly sealant? Also, I have read the pump needs to be mounted below the tank, is that true, and if so where do you mount the tank?
Thx
Mike
Thx
Mike
apperently its better for the pump to be higher but i put it above and it works fine...as for the tapping of the tank...i drilled a hole then tapped it then threaded the piece in there...just take the piece into a ACE and they will give u the right size drill and tap...its realy easy just go slow..
Here's the complete guide of my installation for your kit!
http://www.ticpu.net/~jerome/pics/?path=./meth
I did also get the trunk mount guide, but after some help from AIS, I had this kit installed in one afternoon.
