Anybody running the GM LSJ Clutch Upgrade Kit?
Like the title says, anyone here running the GM LSJ Clutch Upgrade kit? I could use a new clutch and I've had my eye on this one. It's a killer deal and handles 300hp which isn't bad.
Link.... http://www.crateenginedepot.com/stor...P2301C229.aspx I assume it's 300 crank hp, but can anyone confirm whether it is or is not 300whp/300chp? Also for you guys that do have it, how do you like it? What mods do you have done? And how long has it been on your car? Any other info would be awesome, thanks guys. |
there is a guy in new york with a gt35r swapped LSJ making like 360-370whp with that clutch and it isnt slipping even with hard launches on drag radials
Really? That's damn impressive if so.
yep i dont remember his name on here though. he does all his work at SMG motoring
Is it maxim x that has it?
(Post 4462578)
Sweet hopefully he will chime in
i have the clutch , not at 300whp tho. id assume im in the 260 range. iv had 12 passes on the track with no problems yet. feels great no slipeage.
^^Awesome man, thanks for the info, we have pretty similar setups.
Bump |
Originally Posted by Billig ss/sc
(Post 4463956)
Bump |
Originally Posted by phatnackySS
(Post 4464163)
no prob , its the best deal out there ,since it comes with the LNF Throw out/slave. its a stiffer peddle due to higher clamp force.but it feels great. my only complaint is that in engages right off the floor, but that's due to our non adjustable master cylinder clutch rod.
believe ZZP....not sure.
http://www.zzperformance.com/cobalt_...1096&catid=146 yup http://www.zzperformance.com/cobalt_...1096&catid=146 yup |
im gonna be getting it to save for when my clutch needs to be done you guys saying its to stiff need to bleed it look on rlf for how to
i am running this clutch. i absolutely love it. it holds my power with pure ease and seems like it could easily hold more.
Was meaning to create/search for a similiar thread. Thanks! On my list.
I have it.. Its great so far. Maybe 15k miles or more on it.
Originally Posted by ssyellow
(Post 4464790)
273 whp, 268 wtq
1 pass down the strip on slicks, about 1500 Kms on it before I hit the strip if I remember: http://i668.photobucket.com/albums/v...h/52095078.jpg Kevin |
Yep looks like you broke it.
ouch bad install?
nah you need an exedy clutch when using DR...thats it thats all
i have it...only had it about 1500 miles but i love it so far
um i hope this holds a hahn stage 5 swap. turned up:)
Originally Posted by rico
(Post 4465935)
