Anybody running OTTP Stage 4 cams?
South Central *********
well more lift may not be necessary, im curious more so on how the durations are
what power they can support, and if anyone has dynod them yet
i also am interested in the solid lash adjusters
because cam grinding is not 100% mistake proof the centerline can be off a couple of degrees and the adj cam gears will allow you to put the cams back on spec and then you should install the hex
And I'm glad i could help fund your new cam journey, japeatr :P
and for anyone wondering....
Michael, appreciate the help brother!
My car will make the most whp on blower, and spray... It was already close as it was and now im going all out!
I loved the feel of the car when cammed, simply amazing powerband when revving to 8k
Base circle should be 1.180. ZZP had a bad batch they got almost a year and a half ago. It wasn't recent. Advise found out the issue the hard way. His car ran like **** and couldn't figure out why. I received a bad set also but hadn't installed them and ZZP replaced them. All are checked now before they go out. But your cams will be fine. If they weren't Jap would have had the same issues.
Yes I do.
Spec is 30mm but most cams measure at 1.182"
