anyone with 2.85", 42.5lb/hr, maf-t?
I was wondering if anyone else was running a ~2.8" pulley with 42lb/hr injectors and the LSJ maf-t setup. If so, I have a couple questions.
1) Have you used a wideband to monitor A/F? 2) Have you used interceptor gauge to monitor KR? 3) What is your maf-t set at? 4) Any other mods? (specifically an intake?) 5) Do you notice any hesitation at low rpms? I would greatly appreciate any input from guys who have this or a similar setup. Thanks |
1) I have the AEM wideband to monitor my air fuel, YOu need one.
2) I have an interceptor to monitor my KR, and I get less than 2 at all rpms. 3) I believe it is set at D and A im not sure tho dont believe me. 4) I have Fujita intake, exhaust and high flow cat. without the PCM tunning your car will run funny about a couple of hard runs, meaning, hesitation, all you have to do is turn the car off and once its back on the bad boy will be back! (notice how I threw two answers in one) |
I had my car on D and D and man I can tell it was pulling soo much harder however, I was seeing as high as 13s in my wideband. lol, thats waaaay too lean so I tuned it down and now all I see is low 12s, maybe a high 12s on a colder day.
after setting my maf-t to C 1, I kept getting a lean code. So I changed the maf-t to D 0 while the CEL was still on. After 5 minutes of driving, the CEL went away. wideband coming asap.
