Anyone else having this issue?
Old Mar 11, 2011 | 07:41 AM
MrSlickSter06SS's Avatar
Just wondering if anyone else is having issues with they're gears being hard to shift after the car being cold for a while, I know some of the trans mission fluid gets stiff but... Ive never had to fight to put my **** in gear.. and now... my reverse clunks when I try to put it in gear, so to avoid damage I wait and warm the car up... but I have never had this problem before in the past, and it probably started about maybe 2 to 3months ago.. Anyone else..?
Im really hoping my trans isn't going out.. ;(
Last edited by MrSlickSter06SS; Mar 11, 2011 at 07:41 AM. Reason: Automerged Doublepost
Old Mar 11, 2011 | 08:22 AM
kikal8's Avatar
ill almost guarentee u itll go away once it starts getting warmer out. not to say ignore it. if it keeps getting worse and worse then obviously there is a problem. like i know my car makes funny noises and feels weird in the winter but to be honest EVERY car will. my car does the same thing kindof. not in reverse but in other gears right when i start the car.
Old Mar 11, 2011 | 11:31 AM
Yeah thats what I figured but man I like really have to fight to get that thing in first gear, and all the other gears at that.. like its almost ridiculous lol, its almost to the point I think Im gonna bend the little rods connected to the gear shift to the tranny lol, and then to top it off when I go into reverse it clunks very loud.
Old Mar 11, 2011 | 11:38 AM
mrbelvedere's Avatar
could be a throwout bearing or clutch problem or a low tranny fluid problem also
Old Mar 11, 2011 | 11:51 AM
alleycat58's Avatar
When was the last time the tranny fluid was changed and what type was used?
Old Mar 11, 2011 | 02:00 PM
kikal8's Avatar
my brother whos a mechanic said it might be the syncro's
Old Mar 11, 2011 | 02:06 PM
N1ckateen's Avatar
put it into 2nd before you go to reverse. also make sure you are at a complete stop.
Old Mar 11, 2011 | 02:22 PM
G11's Avatar
G11
guarantee is is the TOB had the same problem. emptied the trans fluid and saw brass in it so i thought it was syncros so i took it in for warantee and it ended up being my TOB was bad. stupid thing was that after they found out the problem was they voided my warantee cuz it had an aftermarket clutch in it and ended up paying about 1300 for it....the part that pisses me off is i bought it with the clutch in it from them and they covered nothing!
Old Mar 11, 2011 | 02:24 PM
CanadianCobalt's Avatar
My first gear is a little stiff when cold, opens right up as soon as she is warmed up a bit when it's cold. It can get pretty stiff when it's -30C out.
Joel
Old Mar 11, 2011 | 02:31 PM
KillahB's Avatar
i have an issue with shifting when my clutch is hot, have not had issues with shifting into gear when cold except for a couple times, and those times all I had to do was let the car roll a couple inches and it was easy. When I go hard on the car the clutch peddle travels farther and with less effort but shifting is harder. My solution to that is throwing the car in neutral and pumping the clutch peddle until it becomes firmer.
Old Mar 11, 2011 | 03:54 PM
sternerG85SC's Avatar
any time i had issues goin into 1st gear, i would just try second(usually worked), or depress and repress the clutch, then throw it in 1st. it could be anything. master cylinder, TOB, syncros. unless your know what your doin i would take it to a tranny specilized garage. you could ignore it but you dont want to cause any more damage. if you have a warranty i would get it looked at. better to be safe then sorry. unless money is an issue.
Old Mar 11, 2011 | 05:09 PM
Yeah im not under warranty lol, but ugh yeah I def dont wanna ruin it if something else is wrong, but when its warmed up shifts like a champ but I didnt know if that was a premature problem yet to come you know.. humm as far as the fluid goes I havent changed it... ;X so I guess that would probably help.. thank you all for the input really helps
Old Mar 11, 2011 | 05:10 PM
Wow GM for you Lol.. ty for input
Old Mar 12, 2011 | 07:48 PM
Ok so I went to the auto parts store and they said the trans oil that I need I have to get thru GM so was wondering if anyone else was running something that I can get from the store or what... Any help would be appreciated.. thanks guys!
Old Mar 12, 2011 | 11:27 PM
LSJ's Avatar
LSJ
Here is your bible for fluid changing, capacity, part number, etc, for the transmission on this car.
Read it and enjoy.
https://www.cobaltss.net/forums/driv...thread-230048/
Old Mar 13, 2011 | 07:28 AM
KillahB's Avatar
Yea, finding fluid is near impossible, GM is our only source for the "proper" fluid. Unless you travel to Europe often, in which case they sell the right transmission oil at nearly every automotive store.
Old Mar 13, 2011 | 03:44 PM
Read it and enjoy.
Awesome your the man thank you.
yeah I went to Advance and they didn't have it he said I owuld have to get it from GM.... So stuiped in my opinion..
Last edited by MrSlickSter06SS; Mar 13, 2011 at 03:44 PM. Reason: Automerged Doublepost
Old Mar 13, 2011 | 04:17 PM
LSJ's Avatar
LSJ
No problem!
And yes, the only place you will be able to buy it, is from the dealership. It is a GM part, and there is nothing aftermarket that even comes close. Trust me.
Old Mar 19, 2011 | 08:22 PM
josh6854's Avatar
Try putting it in 1st ALWAYS ALWAYS ALWAYS before reversing. Our transmission is syncronized.
Old Mar 19, 2011 | 08:25 PM
ecot3c inside's Avatar
just a thought.... change your trans fluid with the proper kind, previous owner might have got it changed with a generic. like some may have already said.
Old Mar 19, 2011 | 09:31 PM
Kolt's Avatar
in cold weather its normal after the car sits for extended periods of time to be hard to shift at first. all five speeds do it. gear oil kinda turns to this clay like viscosity when its really cold. if its too difficult to shift (aka can not get into second after first) just slap it into neutrtal and let off the clutch for about a min, then youll be good to go. our cars are more susseptable to cold with the origional fluid.
Old Mar 20, 2011 | 12:05 AM
06SuperSportChevy's Avatar
Amsoil syncromesh. Awesome stuff.
Old Mar 20, 2011 | 12:37 AM
quikdcride's Avatar
how much does it cost to get your transmission fluid changed?
i got a 05 ss/sc 2.0 lsj and i asked the guy to do it when it was at the dealership
and he told me i dont have transmission fluid i was like wtf??
Old Mar 20, 2011 | 11:05 AM
LSJ's Avatar
LSJ
You'll need 2 quarts. It is roughly $55, and very easy.
Old Mar 20, 2011 | 11:21 AM
msonia03's Avatar
Didnt read the hole thing, but my gm tech told me it was the master cyl. And I can get away without fixing it for years if I just pump the clutch like ten times before trying to go into gear. It only happens when my car sits outside over night in the cold. When she sits in the garage overnight shes fine. Maybe just try pumping the clutch.
