anyone ever done this?
http://www.ottperformance.com/store/...Kit-90p918.htm
OTTP Fuel Pump Rewire Kit...my friend did this to his srt-4 and he said its pretty notice able...
Fuel pump rewire is a good idea. The factory wiring is pretty small. I high amperage draw to maintain the 60 psi in the rail will create heat in the wires. This makes the pump less effective and could cause fuel pressure to drop is the pump were to be starved for enough power.
Rewire kit provides a larger wire that draws straight from the battery.
Simple mod and is a must do IMO.
Batteries in the trunk, but factory wires go from battery to engine compartment and back to the pump. It's actually a longer wire run for the Cobalt then other cars.
