Anyone recommend these solid mounts?
Old Aug 29, 2008 | 08:03 PM
rrutter81's Avatar
Just curious if anyone recommends these?
Also is that the tranny mount included? (Havent looked at my mounts/position)
Old Aug 29, 2008 | 08:07 PM
eurochevy's Avatar
guy with tvs has that here ..they're much more stable than the "solid" poly mounts
Old Aug 29, 2008 | 08:11 PM
rrutter81's Avatar
thx for the input
Old Aug 29, 2008 | 08:19 PM
eurochevy's Avatar
Originally Posted by rrutter81
thx for the input
btw pics are up for my rim if u wanna take a look
Old Aug 29, 2008 | 08:21 PM
rrutter81's Avatar
yea i saw, its not bad, but i would have wetsanded them with 2,000 grit sandpaper, then cleared the **** out of them. Then i would have wetsanded the clear if there were any sags and then polished them with a 3m scratch remover.
btw is the triangular mount the tranny mount? just want to confirm this since i dont want to spend more on an extra solid tranny mount.
Old Aug 29, 2008 | 08:24 PM
Jumpin Fool's Avatar
Thumbs up
I have those. Nothing bad to say about them. I also have their traction bars.
rrutter81's Avatar
yes but the solid mount kit is all the mounts yes?
engine and tranny?
im already getting the traction bars.
Old Aug 29, 2008 | 08:26 PM
engine and tranny?
If you order the full set, yes
rrutter81's Avatar
w00t
great!
Old Aug 29, 2008 | 08:29 PM
Raven SS's Avatar
dont know if u tune urself (seen u have some knowledge in it) but these cause alot of false knock..
and the very top one in the pic is the upper passenger side engine mount and the one off to the right is the front lower and the left one is the tranny one....this is 3 out of the 4 mounts but no one (to my knowledge) makes the 4th one
Old Aug 29, 2008 | 08:30 PM
rrutter81's Avatar
oh good to know. All the way through the rpm band or just from a dig?
Old Aug 29, 2008 | 08:32 PM
Raven SS's Avatar
til around 5500 rpms until they settle out...and when u downshift hard...u will have to log and "re-learn" how to drive with them or tune the adders out
Old Aug 29, 2008 | 08:39 PM
rrutter81's Avatar
i already tune my adders out already (1.2 ms). I have a pretty stout formula for my histograms. Infact one is so complex hptuners ***** itself when i make a combination formula.
I wish we could use scripting for the histograms.
Old Aug 29, 2008 | 08:45 PM
Raven SS's Avatar
figured u'd be able to handle it..enjoy turning ur car on and having it feel like its ready to go...made me happy when i came out tired in the morning and my car sounded and felt like a beast
Old Aug 29, 2008 | 08:46 PM
rrutter81's Avatar
thanks for adding in on the convo, and if u want i can send you some of my formulas i use for narrowband tuning that work awesome for a DD (commute) + WOT for power. I know your well respected and would love the critique.
however i use regular hptuners and compare to my lc1 logs for WOT.
Old Aug 30, 2008 | 01:38 AM
paul1588's Avatar
i have these they work great the vibes are a bit bad at first but go away, but make sure to check the bolts after a while,i found mine where coming loose on me
Old Aug 30, 2008 | 01:46 AM
Werewolf SS's Avatar
I do continual tuning ruter and I'm always interested in learning and observing how others do it.
So if I may how do you tune out your false knock. I just went to poly transmission mounts and was wondering that. Thanks I appreciate all the help!
Old Aug 30, 2008 | 03:04 AM
Mr_Slobalt's Avatar
Using Dynamat is the only thing I've ever heard of doing. http://intense-racing.com/Merchant2/...ategory_Code=T
I don't have any false knock with mine. TTR engine mount and Prothane tranny inserts
Old Aug 30, 2008 | 05:29 AM
theneelster's Avatar
The one under the fuse box no one makes. BWoody makes quality stuff.
Old Aug 30, 2008 | 10:21 AM
TurboTechRacing's Avatar
Might want to check these out: They are rated #1 on recent polls on the cobalt forums, and do not cause "false knock" like the Bwoody ones have known to do.
http://www.turbotechracing.com/produ...idproduct=4933
Photos (MANY more colors avaliable too):
Old Aug 30, 2008 | 01:05 PM
qwikredline's Avatar
Gee now the vendors are slamming each other....
Old Aug 30, 2008 | 01:52 PM
Action Jack's Avatar
I've got the bwoody set for the rl and love them, one of the best mods for the car period. I haven't seen wheel hop yet since putting them on (although that might change if the car had something better than cheap street tires on). They do vibrate alot especially with the ac on but you get used to it really fast. It doesn't even bother me anymore, oh and they make the car shift a lot more confidently
Old Aug 30, 2008 | 04:07 PM
Blown 4-banger's Avatar
I have the billet poly mounts from ZZP and I love them. Installed easy, look great, and work really good. After a drive, I feel all relaxed cause its like sitting in a massage chair while you drive
Old Aug 30, 2008 | 04:21 PM
First Bwoody is not a vendor here.... Nor did we slam them, we "re" stated they cause "false knock" which another member stated.
Second, we are just stating another option for members that have had both and stated in the poll the TTR ones were rated much higher.
Old Aug 30, 2008 | 04:46 PM
KillerBee's Avatar
TurbotechRacing has never "slammed" another vendor on this site. TTR is one of the upmost respected vendors on here.
