Automatic supercharged cobalt?
Originally Posted by zinner
Lets bring it down a notch guys.
I have been here a while now. And at the start there was lots of speculation (and we still have a lot) on what can be done with the cobalts and how they will perform. And obviously there are some people here that have had experience with GM models of the past that share simular compenents as the delta platform.
I want to make sure that we all learn from each other and that when questions are posed about posts made by other members that we stay on the goal of making the Cobalt and the 2.0 in the case of this forum a fast/reliable/fun car that provides lots of enjoyment to the owners/tuners that build them. Lets try to remember to remember that we all have our experiences to share, rather practical or acedemic and try to work together.
WOT your a GM tech right, well try to remember you see a lot of the failed transmission and probably don't see many of the trasmissions that hold up.
NJHK you need to remember than you don't see all the broken transmissions that WOT has seen and maybe you should take into account that you and your friends are lucky that you still haven't broken a stock transmission.
The cooler will certainly improve the lifespan of the tranny.
Spacing out the time of Runs/Pulls willhelp alot as well.
Tranny Temp from Autometer in the Pillar or on the dash would help keep an eye on the situation in the tranny as well, it's a fairly easy to install indicator.
Originally Posted by NJHK
Yeah, I might need to pick one of those up soon...thanks for reminding me.
$15.00
http://cgi.ebay.com/ebaymotors/Autom...26419126QQrdZ1
Thanks alot.
Even Manual Transmissions are not bulletproof, I have personally broken a M-22 "Rockcrusher" 4 speed shifting from first to second with the clutch at 6800 rpm with a built 327 that probably only put out about 280 Hp to the wheels and this tranny was used behind big blocks too. Anything can break if you stress it. It was really quite spectacular when it broke I had just pulled the front wheels about 10 inches off the ground and the car had just settled back down and I grabbed second and CCCrrraackkk. That little 64 Chevy II kicked ASS! FRont wheel drive is fun But rear wheel drive is still the Best. Oh there I go reliving the old days, Nurse is it pill time? Oh NO!creamed corn and spinach again.
Originally Posted by alleycat58
Ding ding ding!!!!! Considering the design of the car, I'm VERY inclined to agree. To put an auto in the car would have killed that completely because if they put a track-worthy auto in it the cost of the tranny would have priced it WAY out of the target market.
This would be the reason people, keeping cost down. No GM plot to keep superchargers away from "automatic" drivers, I think the same reason we have cold asses in the winter time with the unheated leather seats
Though, this might help.
http://www.cheersandgears.com/forums...showtopic=7495
NEW YORK – The new Hydra-Matic 6T70 and 6T75 six-speed automatic transmissions are making their debut in the all-new 2007 front-wheel drive Saturn Aura midsize sedan and the front- or all-wheel drive 2007 Saturn Outlook crossover SUV. General Motors co-developed this transaxle with Ford Motor Co., the result being a new six-speed featuring state-of-the-art dimensions and enabling both spacious packaging and potential safety design opportunities.
The 6T70/75’s clutch-to-clutch operation allows for reduced complexity and compact packaging, which enables the transmission’s three gearsets to be on the same axis as the engine crankshaft. This reduces the amount of room necessary in the engine compartment for the drivetrain, both front-to-back and top-to-bottom. The compact size allows vehicle designers to optimize interior room, as well as lower the hoodline for aerodynamic efficiency.
The spread of ratios between first and sixth gear is a wide 6.04:1 overall ratio. This means a lower first gear helps the engine accelerate the vehicle from a stop, and the high top gear lets the engine operate as slowly as possible during cruising. As a result, performance is improved by approximately 6 percent to 8 percent, and fuel economy is improved by 2 percent to 4 percent, when compared to a four-speed automatic transmission. The first gear is a very low 4.48:1, while the sixth gear is a 0.74:1 overdrive, which reduces rpm at high speeds, thereby reducing engine noise and vibrations. Fifth gear is a 1:1 direct drive ratio. The final drive ratios can be tailored to each vehicle’s performance requirements, and the design allows a wide variety of final drive ratios. For the Saturn Outlook, the final drive ratio is 3.16:1, while the Aura sedan uses a taller 2.77:1 ratio.
The 6T70/75 is rated for engines up to 315 horsepower and 280 lb.-ft. of torque, and with its larger transfer gears, a five-pinion input carrier and beefier structural ribbing on its aluminum case, the 6T75 can handle engines up to 315 horsepower and 300 lb.-ft. of torque.
The co-development by GM and Ford meant that many common components of the transmission are shared, along with the on-axis design; but the controls, calibrations and operation of the transmission are unique to each company. Costs and development time were reduced in some areas by 50 percent because of the co-development process.
“The additional gear states are almost like having two transmissions in one,” said Bob Vargo, assistant chief engineer for the new transaxle. “The low first gear provides tremendous off-the-line acceleration, but the transmission is able to use the middle gears to evenly distribute the torque and offers an overdrive sixth gear that helps deliver great fuel economy.”
Because there are six gears instead of four, the difference between ratios is less than in a four-speed automatic, giving the vehicle more options for using the best ratio for speed and load conditions. For example, with the transmission in an optimum ratio on a hill, the engine will not need to downshift or upshift unnecessarily. Driver Shift Control further reduces shift events by allowing the driver to select a desired gear for certain road conditions, such as steep and long hills, and automatic grade braking for descending hills. Automatic grade braking reduces brake pedal usage by calculating the rate of acceleration while descending a hill, and retaining a lower gear in the transmission.
The electronic controls are designed so that the shift feel is calibrated specifically to either the new midsize sedans or the new midsize crossover vehicles through the timing of the shifts and torque converter lockup speeds. The space-saving hyper-elliptical, narrow section torque converter uses a single-plate lockup clutch that employs GM’s proprietary ECCC (electronic converter clutch control) to dampen driveline vibrations.
The Hydra-Matic 6T70/75’s highlights:
Dimensions of 357 mm in length and 197 mm in width approach those of some manual transmissions, and are among the most compact for a six-speed automatic, and for front- and all-wheel drive vehicles with transverse-mounted powertrains
Clutch-to-clutch shift operation for all shifts except 1-2 reduces mechanical complexity and mass, and is calibrated for smooth shift feel
Integrated transmission electro-hydraulic control module (TEHCM) with driver shift control (DSC), auto grade braking for consistent speed in hilly terrain and while towing or fully loaded
Internal control module reduces powertrain complexity
Heat-treated gears are honed for a more precise fit, reducing noise, vibration and harshness
Hyper-elliptical, narrow-section torque converter enhances packaging and maintains efficiency
Reduced number of seals for stronger input shaft design
Adjustable capacity vane-type fluid pump enhances fuel economy
Although used in some low-volume, high-performance sports cars and luxury sedans, six-speed transmissions are rare in midsize sedans and most high-volume midsize SUVs. GM and Ford Motor Co. recognized a need for a transmission that could accommodate increased powertrain performance while delivering excellent fuel economy. The compact size and reduced complexity afforded by the clutch-to-clutch, on-axis design allowed engineers to provide improved performance and economy with six forward speeds.
With its wide ratio spread and capacity for high-torque engines, the 6T70/75 has the capability to transfer more torque to the drive wheels, particularly in the all-wheel drive Outlook. It also helps vehicles to feel livelier at lower speeds for a given engine, particularly at launch or when starting from a stoplight.
The 6T70/75’s advanced clutch-to-clutch operation is designed for smooth shift feel and packaging efficiency. All shifts except 1-2 (the transmission “free wheels” in first) feature clutch-to-clutch operation. The sophisticated electronic controls allow timing the clutch-to-clutch engagements and disengagements so that the transfer of power from one gear to the next is transparent to the driver. The three conventional planetary gears, with three stationary clutches and two rotating clutches, can be packaged in a smaller space without additional freewheeling mechanisms. It’s a simple, less complex design that enables the packaging of six gears in the space of a four-speed automatic.
A sophisticated transmission electro-hydraulic control module (TEHCM) is mounted inside the 6T70/75, reducing vehicle complexity. Similar to the control system used in the Hydra-Matic six-speed rear-wheel drive transmissions, the TEHCM offers improved quality through its hard-wired connections and pre-calibration during the controller’s manufacture.
The unit is located entirely within the transmission and operates while bathed in transmission fluid. Locating the controller internally facilitates the modular design and assembly strategy while also shielding the unit from the outside environment. Temperatures are consistent inside the transmission.
GM’s proprietary model-based controls strategy reaches a greater level of sophistication in the new transverse six-speed transmission family, said Vargo. The 32-bit system incorporates three levels of “learning” that actually allow the components to adapt to one another.
It is not uncommon to have a transmission-control module that adapts to the specific transmission with which it is mated; however, the 6T70/75 accomplishes this with two steps: when the control module assembly is manufactured, and when it is installed inside the transmission.
As with other GM transmissions, the programming optimizes performance characteristics according to a variety of vehicle inputs. Finally, the new six-speed automatic adds another level of adaptability. Certain components within the major subsystems that make up the transmission “learn” from one another – via the controller software – in a unique form of self-adaptation that maximizes the interface of all the “networked” components. This procedure takes place as the transmission “tests” itself and the interaction of its internal components before it is shipped from the assembly plant.
The TEHCM also enables performance-oriented and driver-controllable shift features, including driver shift control (DSC) “tap shift” and auto-grade braking for the midsize SUV and Performance Algorithm Shifting (PAS) for the midsize sedan. PAS recognizes a driver’s particular style of throttle and brake application and essentially “reads his or her mind” and predicts which gear will be most advantageous for performance driving or economical cruising.
Josh@ottp
Sep 8, 2015 10:18 AM
