Balance shaft delete
Old May 6, 2013 | 12:55 PM
574's Avatar
574
In stead of buying the kit, what keeps you from taking the shafts out and just cutting them down so there are just nubs behind the sprockets? I feel like that would be the same thing instead of buying a kit.
Old May 6, 2013 | 12:57 PM
advise's Avatar
you need the sleeves to press in (with a 30mm socket) to block the oil passages to keep good oil pressure
Old May 6, 2013 | 12:58 PM
574's Avatar
574
Oh yeah I forgot about that. I'm debating on doing this, I was just thinking of a cheap way to do it
Old May 6, 2013 | 01:05 PM
jonathan923's Avatar
racecras!
Old May 6, 2013 | 01:41 PM
mrbelvedere's Avatar
you can drill through the side of the block and tap and plug the oil feed then plug the block
Old May 6, 2013 | 03:13 PM
advise's Avatar
This too
There's a how to floating around
Old May 6, 2013 | 09:15 PM
cavfiredesire's Avatar
LZM does sell just the bushings that you tap in for $80 iirc.
Old May 6, 2013 | 09:16 PM
OneCOLDBIZL272's Avatar
Man ill have to look up where I got the sleeve for where I blocked mine off. I just cut the balance shaft off beside where the gear is..
Old May 6, 2013 | 09:20 PM
574's Avatar
574
Please do! Thats exactly what I'm talkin about
Old May 6, 2013 | 09:28 PM
This is not what I have but, basically the same part. when my motor was being put together the machine shop fab'd mine up. But this is the same thing.
Level Zero Motorsports
Old May 6, 2013 | 09:33 PM
I have the remaining balance shafts in my garage so you can see a rough ideal how much has to be cut off. You might want the back half going back in the motor machined flat thou. Ill go grab them and snap a pic of what I cut off.
Old May 6, 2013 | 09:37 PM
574's Avatar
574
I'm still undecided on how much I want a machine shop to do with my block. It would be nice to have them assemble the whole short block but I think that is too much $$. And to have them fab up block off would probably be a lot more
Old May 6, 2013 | 09:40 PM
They are rusty for they are old and I didn't take care of them for they can never be used anyways.
Old May 6, 2013 | 09:49 PM
If you bought that kit. You would only need to press the bushing in your self it's actually not that hard. And as far as a machine work you would just need to take the sprocket of the balance shaft in and have them smooth the back where you made your cut. Unless you have access to a high tech table like band saw. Can't think of the technical name their called at the momment.
Old May 6, 2013 | 10:27 PM
574's Avatar
574
Okay cool, damn what you got in the background....? You building another lsj?!
Old May 7, 2013 | 12:01 AM
Three Lsj heads and complete blocks.... Maybe...
Old May 8, 2013 | 06:43 PM
c130aviator's Avatar
Got my deletes from mongo for 25 bucks. Block offs from level zero ran me 80. I think I picked up power at the wheel since there is less crap spinning as well.
Old May 8, 2013 | 06:49 PM
Cobalt_SSTuner's Avatar
damn D-Reck how many complete motors you got? I have 2 Want some stock parts?
Old May 8, 2013 | 06:55 PM
no **** you picked up power from less crap spinning that's a novel assessment
Old May 8, 2013 | 07:03 PM
574's Avatar
574
Lol
Old May 8, 2013 | 07:05 PM
Well I should have given you a little more info. I was thinking compare to just doing a nbs. Lol
Old May 8, 2013 | 07:09 PM
Well said!
Old May 8, 2013 | 07:12 PM
Omnigear's Avatar
its 30bucks for the del kit...
Old May 8, 2013 | 07:24 PM
Lol no its not.
Old May 8, 2013 | 07:29 PM
Originally Posted by Cobalt_SSTuner
Well said!
He is a poet. Thought I would state that they are a better option and less expensive than neutral balance shafts.
