Bass_Waves most indecisive build thread ever
Old 07-12-2017, 06:16 AM
  #51
63 Nova SS's Avatar
That car looks really clean, nice pickup.
Old 08-03-2017, 02:23 PM
  #52
Bass_Waves's Avatar
Got the f23 trans. 4.17 final drive. Low miles.
Old 08-03-2017, 02:25 PM
  #53
Bass_Waves's Avatar
Got the ottp f23 solid mount. Love getting parts delivered.
Old 08-03-2017, 07:59 PM
  #54
southal cobalt's Avatar
What all else is needed for f23 swap other than the mount, cables, and trans?
Old 08-03-2017, 09:18 PM
  #55
Bass_Waves's Avatar
axles. I'll find out what else is needed. This 1 is getting a lsd install
Old 08-05-2017, 12:21 PM
  #56
Bass_Waves's Avatar
Bolts are here
Old 08-05-2017, 03:16 PM
  #57
63 Nova SS's Avatar
Good stuff
Old 08-06-2017, 12:58 AM
  #58
that would be awesome. ive thought about going to an f23 for a bit now too. Those are so much easier to get ahold of
Old 08-07-2017, 04:20 PM
  #59
Bass_Waves's Avatar
lol drain for my block showed up.
Old 08-07-2017, 04:31 PM
  #60
jdbaugh1's Avatar
I assume you are still running an LSJ block with an oil cooler? Other than clearance issues it will bolt up fine. There is a massive interference of the shifter cable bracket top bolt part and the T-stat housing. This time around I hacked up the bracket to get the T-stat housing to clear. However, I think it may have turned out neater if I had modified the T-stat housing instead.
There is also interference with the oil cooler and that round hump on the transmission where the TOB connects to the line but it can be easily fixed by grinding down the casing a bit.
Old 08-07-2017, 05:16 PM
  #61
Bass_Waves's Avatar
No oil cooler. It's a gen 3 block. I'm also using a lnf thermo housing because I'm doing the f23 swap at the same time.
Old 08-07-2017, 05:20 PM
  #62
jdbaugh1's Avatar
No oil cooler no problems then.
Old 08-07-2017, 05:24 PM
  #63
Bass_Waves's Avatar
yeah man. I even had a modified plate to run an external oil cooler. But then went this route. Now I just need to put the block on the stand. Get the pistons out. Put new pistons in.
Old 08-07-2017, 05:33 PM
  #64
jdbaugh1's Avatar
So for the LSD did you pick up a Quaife? I just bought an f23 out of a Cavalier with a quaife in it actaully from an ad on this forum. Do you think any ol transmission shop could do the swap or is this pretty easy to mess up? I can't decide if I am going to wait until my current trans or clutch starts giving me problems or if I will go ahead and get the swap done this winter. Should make it a lot more fun for autocross were I have a lot of trouble putting power down out of a corner.
Old 08-07-2017, 05:58 PM
  #65
Bass_Waves's Avatar
no. I went with a team green lsd insert. I expect to blow up a trans or 2.
I was actually gonna try to get that trans. It's different than the f23 that bolts up to our cars. As for the internals. I'm not too sure about it.
If by any chance the f23 survives some beatings. I'll get an actual lsd unit for a trans I can pick up anytime.
Old 08-07-2017, 06:02 PM
  #66
jdbaugh1's Avatar
Yeah the casing is different but I really only bought it for the Quiafe, having a spare set of gears is a plus.
It will be interesting to see how it goes for you. I always wondered how long and how well those inserts would perform.
Old 08-07-2017, 06:13 PM
  #67
Bass_Waves's Avatar
My buddy runs the same insert. He is pushing 600 and it's doing fine for him.
Old 08-12-2017, 09:07 PM
  #68
Bass_Waves's Avatar
And bought another redline. ......it's blue. Runs and drives so much for working on blue cobalt
Old 08-12-2017, 10:11 PM
  #69
Lol how many cars do you have?
Old 08-12-2017, 11:33 PM
  #70
Bass_Waves's Avatar
I'll count them tomorrow
Old 08-13-2017, 08:09 AM
  #71
63 Nova SS's Avatar
You have too many to work on
Old 08-13-2017, 11:45 AM
  #72
Lol if you don't know I think the answer is to many
Old 08-13-2017, 12:26 PM
  #73
Bass_Waves's Avatar
8 cars.
Your right. I may just finish the budgetline SS and the blue redline and sell them both. Can fetch a pretty penny
Old 08-13-2017, 02:59 PM
  #74
Well would be nice for you to keep the budget irl would make a nice daily for sure
Old 08-13-2017, 03:08 PM
  #75
Bass_Waves's Avatar
I daily drive my f150 platinum. It kills me in gas but I go anywhere and everywhere with it. I was gonna sell the truck and keep the redline but that may go out the window soon.
