belt making sounds and bypass valve ?
hey everybody 2 ?S first my one of my belts is like making a sqeeling sound when im idle it allmost sounds like its from the supercharger belt but not sure and ? 2 i was on a superchager site and it says any supercharged car with more than 7psi should have a bypass/blow off valve do we have a stock bypass in our car or is that just pointless?
we have a bypass valve built into the supercharger. as for the sounds, until you post a video of the sound, its hard to diagnose. Since its at idle, it wouldnt be belt slip, so im gonna lean towards your timing chain tensioner, since that seems to fail on these cars a decent amount
I have the same noise at idle. Def. sounds like coming from the belt. Need info as well.
Bump. Looking for more info.
Gonna test taking the belt off and seeing if it still makes the noise. |
Originally Posted by damien
(Post 3858443)
i had a horrible belt squeal, so i replaced the belt. it went away but it came back. i would spray water or wd-40 on it while it was running and it would go away. come to find out it was the belt tensioner, so i replaced it and it has gone away. i do have a slight squeak but it's sooooo much better than what it was. my s/c pulley isn't directly lined up with the rest of the pulleys and i highly believe that's the cause of the little squealing i have now. go to gmpartsdirect.com for the belt tensioner, cheapest brand new one i could find.
Originally Posted by RedEcotecSS
(Post 3858452)
...and putting what on in it's place while you try to reproduce the squeel?
If it still makes noise, time to diagnose the timing chain tensioner. |
(Post 3858452)
Not really. I can do the belt in 5 minutes. Without that squeelc I can better diagnose a bigger problem.
