belt making sounds and bypass valve ?
hey everybody 2 ?S first my one of my belts is like making a sqeeling sound when im idle it allmost sounds like its from the supercharger belt but not sure and ? 2 i was on a superchager site and it says any supercharged car with more than 7psi should have a bypass/blow off valve do we have a stock bypass in our car or is that just pointless?
we have a bypass valve built into the supercharger. as for the sounds, until you post a video of the sound, its hard to diagnose. Since its at idle, it wouldnt be belt slip, so im gonna lean towards your timing chain tensioner, since that seems to fail on these cars a decent amount
i had a horrible belt squeal, so i replaced the belt. it went away but it came back. i would spray water or wd-40 on it while it was running and it would go away. come to find out it was the belt tensioner, so i replaced it and it has gone away. i do have a slight squeak but it's sooooo much better than what it was. my s/c pulley isn't directly lined up with the rest of the pulleys and i highly believe that's the cause of the little squealing i have now. go to gmpartsdirect.com for the belt tensioner, cheapest brand new one i could find.
If it still makes noise, time to diagnose the timing chain tensioner.
the only vital component the belt moves is the alternator. the battery should have enough juice to run the engine for 30 seconds or so with no problems. but yea, im on the same page as you, in that its a weird approach to go by to trobleshoot
DANRICKARD
Oct 1, 2015 12:08 AM
