Best Aftermarket Clutch
Old Jan 30, 2009 | 03:08 PM
jwolf8604's Avatar
What is the best aftermarket clutch? I've heard the hypersingle but I want durability cause it is my DD and I just need to make sure it is a reliable product and holds about 260-300 hp.
Also, Is there anything else that I need to be concerned about when replacing my clutch? Will my transmission and everything be fine?
Old Jan 30, 2009 | 03:15 PM
roadrage06's Avatar
check out the Exedy clutches. you won't need to go crazy expensive with your goals.
EDIT: Stage 2+ seems to be the most popular.
Old Jan 30, 2009 | 03:16 PM
CptTheAlex's Avatar
Its torque your really need to worry about not the hp.
Old Jan 30, 2009 | 04:30 PM
jwolf8604's Avatar
how much should I try to bargain for installation price? 500 too much or too little?
Old Jan 31, 2009 | 09:08 PM
tdipowered's Avatar
bump for result?
Old Feb 1, 2009 | 04:20 PM
jwolf8604's Avatar
bump on install price????
Old Feb 1, 2009 | 04:25 PM
bluechevycobaltss's Avatar
around here when i helped my friend call around for a clutch install on his integra the cheapest price we found was about $250 most people wanted $300 and i think that included resurfacing the fly wheel. Im not sure if prices will vary for different areas tho.
Old Feb 1, 2009 | 06:45 PM
Sharkey's Avatar
integra is about a 3-4 hour job were the cobalt is 8.1. expect to pay over $600 for the install.
Old Feb 1, 2009 | 08:08 PM
jwolf8604's Avatar
like my op said. I'd shoot for bargaining 500 bucks
Old Feb 1, 2009 | 08:11 PM
BLAZIN07SS's Avatar
I'm too JDM for you
wtf? my buddy did one in 6 hours from putting the car up on jackstands and bringing it back down in his driveway laying down.
Old Feb 1, 2009 | 08:14 PM
Sharkey's Avatar
book time on a clutch job on any cobalt is 8.1 hours, that s what would normally be billed out at a reputable shop, weather it takes then 5 hours or 12 hours.
Old Feb 2, 2009 | 02:06 PM
Plastic's Avatar
Centerforce DFX FTW, soft pedal with no slipping.
And 600 kind of seems like alot for a clutch job, a local shop did mine for 300 and that included the Royal Purple trans fluid too.
Old Feb 2, 2009 | 02:07 PM
1badBlueberrySC's Avatar
If you go with spec make sure it's the "+" series of them!
My money would go with Exedy myself!
Old Feb 2, 2009 | 02:11 PM
tdipowered's Avatar
the stage 2+ is more expensive than stage 3...why not just go stage 3?
Old Feb 2, 2009 | 02:23 PM
the + series are better clutches....
Old Feb 2, 2009 | 03:01 PM
1bdstlLSJ's Avatar
GMPerformance just came out with a clutch kit......Im betting that is a good setup!
Old Feb 2, 2009 | 06:29 PM
car_guy_09's Avatar
I plan to get the GMperformance clutch and its supposed to be good to 300
Old Feb 2, 2009 | 07:00 PM
jwolf8604's Avatar
I wonder what the gm label has for its install time. it would be pretty sweet if it could be bought and installed by a dealership for 1100 or less
Old Feb 3, 2009 | 05:43 PM
tdipowered's Avatar
i dont understand how a stage 2+ could be better than a stage 3 cltuch?
Old Feb 3, 2009 | 05:46 PM
GTCAMM's Avatar
dunno bout anyone else but i had my stg2 exedy clutch and fidanza flywheel installed for 550 flat. and less than a month later, my release bearing is almost gone and i had to replace the stock tranny.... unless u need it, id stay stock or stg1.
Old Feb 3, 2009 | 05:47 PM
OntarioKev's Avatar
So you replaced the clutch, but didn't replace the slave cylinder while you were doing it?
Kevin
Old Feb 3, 2009 | 05:48 PM
BERTOSS's Avatar
A stage 2 from exedy or ACT will be the best buy..plus not many brands have clutches for the ss/sc
Old Feb 3, 2009 | 05:49 PM
GTCAMM's Avatar
i have no idea, i just gave them the boxes that all the **** came in and told them to install it, i figured nothin cud go wrong.... man was i wrong, 1 tranny later and now il be replacing the release bearing.
TurboTechRacing's Avatar
It is the type of material that is used, 2+ will hold more than the stage 3
IMO SPEC "+" series are the only ones I would use, other than the Exedy hyper single...
Old Feb 3, 2009 | 05:51 PM
Smarty Art's Avatar
Stage 3 Exedy and no problems so far. I have about 5K miles on it. Stiffer pedal feel and a little bit trickier to start on hills but not bad once it breaks in. We installed it in a day on jackstands. We have it down to 5-6 hrs to do one now. A dealer is going to mark up the part and charge more then a shop.
